Renntech C250!
Old Apr 26, 2012 | 09:35 AM
  #201
Trek1200's Avatar
1989 300TE, 1981 380SL, 1990 325I, 2002 Overland, 1976 BMW 2002,
Originally Posted by benzbeginner
Glad you are getting to drive your car.
Yeah, thank the baby Jesus. Only problem now is getting used to the dang electronic throttle. Anybody know of a way to set the default transmission setting to sport instead of economy?
Old Apr 26, 2012 | 10:11 AM
  #202
MDMercedesGuy's Avatar
2024 GLS450
It can't be changed to default to S on the newer cars.
I actually find that I prefer E now and let the midrange torque do the work - I'll pop it to S if I have to make a quick getaway from a light or such, but stick it right back in E when I am done. Revving the snot out of it doesn't seem to make it much quicker.
Old May 5, 2012 | 01:10 PM
  #203
_Bondo_'s Avatar
2005 CLK500
Any update here?
Old May 6, 2012 | 01:08 AM
  #204
StuttgartUSA's Avatar
2012 C250 Sports Sedan, 2006 AMG E55
Another perfect example of a onnce mighty tunning company going down the crapper. Cant break a code on a ECU, I say BS, little to no effort put into this.
Old May 6, 2012 | 12:57 PM
  #205
Knightmare69's Avatar
2010 C200 CGI
Originally Posted by Trek1200
Pics to follow shortly.
Still waiting...
Old May 6, 2012 | 01:19 PM
  #206
Igor1080's Avatar
2013 C204
It's obvious here that Renntech does not see this car as a priority. Personally I would have flipped a sh*t if they had my car for more than 2 weeks.
Old May 6, 2012 | 02:21 PM
  #207
Tim Bailey of Cobb tuning fame, there head tuner, told me any ECU can be cracked locked or not in less than a week. He broke the GTR locked code in less than two days. From what I understand that ECU was the most encrypted ECU ever. I doubt Mercedes locked ECU presents much of a problem to a real tuner.
Old May 6, 2012 | 02:23 PM
  #208
And that is the odd part, the C250 will be the bulk of the sales in there lineup. I went with the C250 for one reason it was a turboed 4. I though that the tuning options would be endless. I guessed wrong.
Old May 7, 2012 | 06:34 PM
  #209
Trek1200's Avatar
Ok, update time. Renntech is still not done with the tune. They've got the code broken at this point and are experimenting with the ECU they have right now to make sure it sticks. I'm told that they have been getting a pretty serious amount of inquirys on the 250 tune, and you're right, it probably will be the bulk of their customer base. Yes, it is a colossal pain in the *** that I've waited so long to have nothing yet, but Renntech is a pretty solid company and I'm sure they'll get it done soon. In the meantime, I just picked up a 1981 SL380 (150hp out of a 3.8 V8, yawn), so I'll be driving that on nice weather days for a bit. I'll keep everyone updated.
Old May 7, 2012 | 06:39 PM
  #210
Trek1200's Avatar
Cobb should get on it if Renntech is so far behind. There's loot to be made.
Old May 21, 2012 | 10:31 PM
  #211
Mabuhay's Avatar
C63 AMG
Has anyone played with the "poor man's" variable boost control? Back in the Eagle Talon / Mitsubishi Eclipse days, you could attach a "bleeder" hose before the wastegate that effectively fools the wastegate into thinking it had less boost and thus, would delay opening. I.e. - If the max boost on the C250 is 10 psi (I don't know the exact number), the wastegate would open to allow anything over 10 psi to "bleed through". So if you bled out 2 psi of boost and the wastegate maxes out at 10 psi, your engine will actually "see" 12 psi of boost and the injectors would compensate for it up to a point.
Then again, I'm wondering if OBD2 diagnostics since 1996 prevents this scenario anymore by "knowing" exactly what boost the engine is seeing and would then crank it back down regardless of the wastegate. Or it could also throw a Check Engine Light (CEL).
Anyone know for sure?
Old Aug 14, 2012 | 09:35 PM
  #212
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
Guess this never panned out...
Old Aug 14, 2012 | 09:44 PM
  #213
Igor1080's Avatar
2013 C204
I've had my JB+ for probably 5 months. This is a retarded waste of time.
Old Aug 15, 2012 | 10:56 PM
  #214
kevink2's Avatar
2004 Mazda6, 1993 RX7
I HAVE THE CAR!!!!!! .... In the interim, I'm going to try out the Burger tune and see how that works, then once the Renntech tune is done, I'll have some comparo data for everyone. Pics to follow shortly.
I recall the Renntech promised about 30hp and 40ft-lbs of tq, which is what the JB (juice box) provides.
I contacted JB, asking if they minimized retard when building boost at lower rpms. I had found that this is critical in tuning a turbo. They said they wanted to, but could not do it, so on the A-B dyno runs you can see they follow the same initial trace on the dyno chart. They basicly just changed the boost curve and richened the mix at wot.
Did Renntech say which ECU/CPU parameters they changed ?
Old Aug 17, 2012 | 03:59 AM
  #215
2010 C200 CGI
Weird, they didn't tell me anything about changing the boost curve. What I was told was that they advanced timing and richened the fuel.
Old Apr 27, 2014 | 10:41 PM
  #216
janusgrimnitz's Avatar
C200 4matic
SO the Burger chip doesnt work?
Old Apr 27, 2014 | 10:57 PM
  #217
2010 C200 CGI
No, I think what he meant was that since Burger has had a piggyback out for our cars for at least 5 months, it's a waste of time to wait for the Renntech.
Also as an update, I was told from a source in Renntech on another board, flash tunes for our cars basically won't be happening. CGI motors run a Siemens ECU, unlike the Bosch one used in the CLA, it's essentially unhackable. At the very least, not worth it for tuners to hack from the feedback I'm getting from many brand name tuners.
Old Apr 28, 2014 | 01:46 PM
  #218
RENNtechHQ's Avatar
Former Vendor of MBWorld
Mercedes-AMG
We have a C250 Piggy Back unit we are working on right now that is simular to our CLA45 Piggy Back as there is a tunerblock on the ECU that we cannot get passed on the C250. We have the unit on a street car and logging some miles on it. We hope to have it out soon but we want to makesure it is up to RENNtech standards and performs as well.
Old Apr 28, 2014 | 08:32 PM
  #219
2010 C200 CGI
Would this work/be compatible with the c180/200?
Old Apr 29, 2014 | 09:06 AM
  #220
RENNtechHQ's Avatar
Mercedes-AMG
No it would not.
Old Apr 29, 2014 | 02:29 PM
  #221
Project C's Avatar
MB C250
Good to hear that
btw what is the estimate price and power gain
Old Apr 29, 2014 | 02:36 PM
  #222
RENNtechHQ's Avatar
Mercedes-AMG
Not sure yet on either one yet. We have the low end and mid range feel pretty good right now and have about 200 miles on the test car. We are working on making some more top end power at this point. It is not easy on this car with the piggy back but we are working on it. As soon as we are ready to release the pricing and power info I will post it up right away.
Originally Posted by Project C
Good to hear that
Old Apr 29, 2014 | 02:46 PM
  #223
Project C's Avatar
MB C250
Definitely looking forward to that
Old Apr 30, 2014 | 02:00 AM
  #224
C200 4matic
No it would not.
Old Apr 30, 2014 | 07:41 AM
  #225
2010 C200 CGI
No it would not.
Not going into how your piggyback works compared to the other brands. Being that the c180/200 is closely related/similar to the c250, is it possible to create a version for them?
