Door Handle Removal
Old Dec 22, 2011 | 01:09 PM
dcvampire's Avatar
2009 C300 4Matic
Door Handle Removal
Hey this is my first post.
I am just wondering if anyone know how to remove the outside door handle for the rear door. It is rattling.
Thanks!
Old Dec 22, 2011 | 07:01 PM
JaCe88's Avatar
GLE 300d (v167)
When I got my car done recently it turned out they needed a special tool to undo the handle to get it out. Could be purchased from a generic hardware shop as it wasn't that rare.
Front handles come off alot easier.
Old Dec 24, 2011 | 05:27 AM
got_thang?'s Avatar
2008 C350
Bought mine from a sears hardware store, t20 is the size you will need
it's gonna look like this
Old Dec 24, 2011 | 11:13 PM
mikonuj's Avatar
2014 C63 AMG Edition 507
DIY: How to remove Door Handles [Pictures and Instructions]
I used a 9"Craftsman T20 Torx Screwdriver for this DIY.
So here we go:
First, locate the rubber grommet that's inline with the door handle...
...and remove it.
Aim your T20 Screwdriver so that it is level with the door handle and insert so that it reaches the torx screw. The amount of remaining driver length shown is the amount you should have left after the tip of your screwdriver reaches the screw. Unscrew, but don't remove the driver. Unscrew to where it seems the screw is no longer retracting, but don't pull the driver out. Leave the driver inserted; otherwise you will lose your screw in the door casing and you will be f***ed.
With one hand, pull the door handle. With the other, wiggle pull the other piece; the rear piece should pull straight out.
Like so.
Next, grab the door handle and slide it back. Use ample force and you should feel the door handle disconnect and slide back.
Start by pulling the back portion out...
Using a pulling/turning motion, pivot the door handle like shown. And the door handle should just come out.
Hope this helps and good luck! btw, MERRY CHRISTMAS!!!
Old Dec 26, 2011 | 04:38 AM
dcvampire's Avatar
2009 C300 4Matic
Wow! thanks got_thang.. and thanks mikonuj for such detailed instruction! This will help me a lot! MERRY CHRISTMAS guys!
Old Dec 30, 2011 | 03:47 AM
Kaewen's Avatar
GLC250 Coupe
So here we go:
...and remove it.
Like so.
Thanks for the detailed instruction.
DId you Plasti Dip your door handle?
Old Oct 24, 2012 | 01:51 PM
kHuNkHuNa's Avatar
White 2009 C300 Sport
well, ur pictures are gone, and i want to do this, so i can wrap my car
do i have to remove the inside door trim in order to take off the door handles? or is there a cover thing that pops off on the outside that has a screw beneath it
Old Oct 26, 2012 | 01:20 AM
got_thang?'s Avatar
2008 C350
no you just need to pull the cap off from the door and loosen up the screw
Old May 20, 2013 | 03:28 PM
SheryarYO's Avatar
C63
So here we go:
...and remove it.
Like so.
would it be possible to reupload the pictures by any chance?
Old May 20, 2013 | 04:16 PM
PelicanParts.com's Avatar
SPONSOR
Answer
This DIY is on the W201 but still may you.
http://www.pelicanparts.com/techarti...or_Handles.htm
whunter@pelicanparts.com
