Adding screens that work with factory DVD player.
I would like to add 4 more screens that will mate with the factory DVD player and allow me the opportunity to use the factory setup. I am in the process of turning my 2008 C300 to a show car and need some advice.
I have checked out the Midcity VIM and I am not sure if that will solve my problem. I could install a separate DVD player under the seat but I would prefer to use the factory one.
I did something similar in my last C230 but I installed a DVD player since the car did not have one and wired it through the AUX jack in the glove box so the sound would play through the factory speakers. I don't see an AUX jack in my C300 so I am looking for other options.
Thanks for the replies.
Can I use a fakra adapter to make this work. I have the HK sound in my new car.
Thanks for the info. I sent midcity an email, hopefully they will chime in and help me out.
Also both systems Audio 20 and command use MOST fiber optics and your stereo will not work unless the chain is continuos and all of the items on the chain are programmed in. You will most likely need a dealer visit to have it programmed for the add on devices unless the splitter works without causing any issue to things further down the line
I used a hi-low adapter to connect my amp & subs in the trunk and hooked it to the rear door speaker wires.
I guess I never realized it was fiber optic because I had the basic head unit in the car.
Midcity has offered me a solution that will allow 4 more screens to play off of the factory DVD player and I can still add my backup camera. I will have the VIM as well but I do not plan on using it, I just want to be able to have the other screens playing the same movie as the screen in the dashboard.
I am going to order everything next week and I will let people know how it goes.
