Will LED tail set off Error Message?
Old Dec 30, 2011 | 06:00 PM
areyouin's Avatar
c300
I've searched but couldn't find what I was looking for...
Looking to upgrade the tail lights to the OEM LED's but I'm not sure if it will set off any errors...
Old Dec 30, 2011 | 09:26 PM
Invain15's Avatar
4matic C300
Year and package you have on your car
Old Dec 30, 2011 | 09:31 PM
areyouin's Avatar
c300
Sorry. 08 basic. No lighting package or nav, if that helps
Old Dec 30, 2011 | 10:09 PM
victort's Avatar
2010 C300
yes, you will get error codes
Old Dec 30, 2011 | 10:50 PM
areyouin's Avatar
c300
Damnit...I don't think that'll stop me though
So what's the deal with the error message? Every time I turn on the car there's a message and I press "ok" and it goes away or does it stay there?
Old Dec 31, 2011 | 12:57 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Absolutely not. The OE taillights, LED or stockers are interchangeable without any errors or programming unless you are referring to the new 2012 versions.
The aftermarket LEDs from deepest China or California are another matter.
Personal experience.
Old Dec 31, 2011 | 10:17 AM
Invain15's Avatar
4matic C300
Yes that's basically it.
Old Dec 31, 2011 | 10:24 AM
areyouin's Avatar
c300
Ok cool thanks guys!
Old Dec 31, 2011 | 04:07 PM
acr2001's Avatar
2012 C300 4Matic
Not so fast! These guys have failed to mention that the LEDs are not likely to work at all! Not only do you get a very annoying error, but the computer will turn power to the light OFF. At best, you will have flickering LED lights. Forget it! You need error cancelers (resistors).
Old Dec 31, 2011 | 04:28 PM
areyouin's Avatar
c300
So many different answers... I'm hesitant to get them at all now. But there has to be people who upgraded to these lights...right?
Please chime in
Old Dec 31, 2011 | 05:46 PM
until the end's Avatar
2009 c350 arctic White pano. MM HK
I changed my tails to oem led and no error mass. 2009 c350 withot lighting pac.
Old Dec 31, 2011 | 05:52 PM
acr2001's Avatar
2012 C300 4Matic
With regards to the OEM LED tail lights rather than aftermarket LEDs, I am honestly not sure. Either you get the error, they have load resistors built in to prevent the error, or this last poster had his installed by a dealer who coded the car for LED tails thereby preventing the error.
Someone must know the answer to this question for sure...
Old Jan 1, 2012 | 12:07 AM
RLE's Avatar
RLE
If the OP had said whether he was talking about the new 2012 lights, the answer is different than if he means the earlier LED versions.
Not enough info.
Old Jan 1, 2012 | 11:15 AM
bnam's Avatar
2009 C300 Sport
Ok, let's clarify (I had similar question) -- using an OEM '08 to '11 LED tail light in a basic package '08-'11 non-LED taillight car -- will it work without errors? Or if there are errors, can they be removed by dealer programming?
What about the '12 OEM LED tail lights in '08-11 non-LED cars?
Thx!
Old Jan 1, 2012 | 12:25 PM
Richard2011's Avatar
2015 BMW M235i 6MT
Hot_Fur, who bought Derspeed's C300, has OEM LED taillights without P2 and says he bought it from Derspeed like that, so maybe Derspeed could chime in on what he did to get them to work. I assume you would have to have the dealer reprogram for LED taillights.
Old Jan 1, 2012 | 10:32 PM
RLE's Avatar
RLE
Completely totally false.
Old Jan 1, 2012 | 10:37 PM
RLE's Avatar
RLE
Thx!
Once again:
Question 1:Yes.
Question 2: See answer #1.
Question 3: Programming required.
Old Jan 1, 2012 | 11:52 PM
acr2001's Avatar
2012 C300 4Matic
Woah lets make sure we are on the same page - I think I was unclear, my fault.
I am stating that if you install LED lights that do not have an error canceler (extra resistor that mimics the wattage of the bulb it replaces) you will very often get flickering of the light, and very often it wont light up at all. This is on top of the error that you get.
If this is what you are referring to, then I promise that I am correct and it will flicker / turn off more often than not.
If you mean with the OEM LED tails that are pre-2012, those are not what I was referring to as I honestly do not have a clue with regard to those -- that's why I had made a second post which addressed the OEM tails to be clear.
Old Jan 1, 2012 | 11:54 PM
areyouin's Avatar
c300
I might just have to buy them to clear the air in here lol
Old Jan 1, 2012 | 11:58 PM
acr2001's Avatar
2012 C300 4Matic
I might just have to buy them to clear the air the here lol
It sounds like RLE knows what hes talking about with regard to the different OEM tails. My post was in regard to aftermarket LEDs. Sorry if I confused.
Old Jan 2, 2012 | 12:04 AM
RLE's Avatar
RLE
I refer you to the original post which referred to OEM to OEM.
"...I've searched but couldn't find what I was looking for...
Thanks.."
So, your posts about non-OEM seem to be inappropriate since they are not the subject of this discussion and just introduced an unneeded fog factor.
Old Jan 2, 2012 | 12:24 AM
acr2001's Avatar
2012 C300 4Matic
Thanks.."
Well, I did make an additional post to clear that up. No use arguing semantics though, you're right I did probably add confusion. Glad we sorted it out.
Old Jan 4, 2012 | 10:02 AM
SuPERSaK's Avatar
08 C300
Will the 2012 taillight PNP on the 08 C ?
Old Jan 4, 2012 | 04:57 PM
RLE's Avatar
RLE
I GIVE UP.
Old Jan 4, 2012 | 05:10 PM
areyouin's Avatar
c300
Lol I didn't even attempt
