NEW W204 TAIL LIGHTS
Black C300
I pmed him he said 200 plus shipping. thats too much to for me to spend on a damm three led lights to be off so i just let it stay as is until something cheaper solution comes on the way
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
I saw somebody else in the main DIY thread with the brake light partially on when lights are on, in addtion to the left fog
Black C300
about to get the group buy complete for the reprogram... just need 1 more person for $100 off
I was wondering though.... does anybody get the check right rear foglamp error message when installed?
I thought the error was with the left fog?
#32
15 Mercedes C400, 12 Mercedes C250 coupe
I have the north american tails (red blinkers)
and fog on driver side but have the error for both LEFT and RIGHT sides about foglamp
For now I have the green wire pulled from the harness, so my rear fog light is disabled
#33
weird.... must be a programming issue canada vs USA models or the options packages of your car vs mine
#34
2010 C350/ E46 M3/MK5 DUB
2012 tails
So basically $200 plus shipping to reprogram the Sam box, is the only way to get these to work as the factory intended? Im in the NY area has anyone had this upgrade/retro performed as of yet? I know a dude in Brooklyn that has the equipment and most likely the know how to program the box in worse case senerio. Problem is he will most likely want more money to do e work, then it would cost to just go out and buy a 2012 entire car for....
#35
#37
If I get a set of tails along with the Sam out from a 12' will they work without needing a reprogram? Reason being there is a 12 at a local junk yard near to me. I want to stop by and see if they will sell the 3 pieces to me if need be. If not I'll just get them new. RB, did you get Yours from, Parts.com? Are the 204 820 41 64 and 28 64 part numbers accurate? Last thing, is there and stove group purchase list in circulation? Thanks gents....
#39
I've just cracked my rear tail light on my 2010. Have read many posts about the 'face lift' tail light issue / problem in so far as the lights not correctly illuminating.
Searching the web I came across these. (see link)
http://www.k2motor.com/search-result...ED+Tail+Lights
Has anyone bought these?? Any advice is apperciated. Thanks
#40
1 Post
2009 C300 Sport 4MATIC™ Sedan
#41
2010 C200 CGI Palladium Silver
See this thread
#42
Does anyone know if these are plug and play or require programming?
