Need advice on removing rear two cats on a W204 C300 Petrol
Old Jan 20, 2012 | 04:06 PM
DEE-AMG's Avatar
C300 BLACK
Hello All,
I am considering taking the two rear cats off my exhaust system. But having some doubt?
Was at a Mercedes specialist today, he advised, not to take the rear cats off my car. Reason being, it would cause the front cats to work extremely harder. Also he said the Lamber sensors at the front would be giving wrong readings to the rear sensors and would throw up the engine management light. Long term, he said it is not a good idea.
I am booking my car into an exhaust garage to have the following done.
Take rear two cats off. (unsure yet)
straight pipe into (magnaflow) x pipe or a custom H pipe?
change the two mufflers for 6 x 3 oval silencers. (I think the smaller the mufflers, the better the sound?)
staggered quad 4 x 3" tips.
All advice and help much appreciated.
Old Jan 20, 2012 | 05:26 PM
bhvrdr's Avatar
2012 e350, a BMW, an Audi, a Camaro
Originally Posted by DEE-AMG
Hello All,
I would think that removing the back cats would actually cause a reduction in backpressure and corresponding exhaust gas temperatures if anything causing the two remaining cats less wear and tear. In addition, your primary lambda's are for measuring o2. They are pre-cat. The secondary lambda are for monitoring cat performance. They do not change mixture control. They will simply throw a code but no affect on performance should occur.
cheers! mike
Old Jan 20, 2012 | 09:29 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Don't...
Old Jan 21, 2012 | 09:04 AM
DEE-AMG's Avatar
C300 BLACK
deciding to not bother touching the cats at all until they are worn and need changing.
as for the mufflers/silcencers. am i right in saying, the smaller the box the better sound quality?
Old Jan 21, 2012 | 12:12 PM
bhvrdr's Avatar
Not necessarily. Sound quality is also subjective. I'd choose a muffler with a sound you will like from reviewing/listening to others who have already used them. I'd also choose one that uses straight through cores for the best performance. Companies like magnaflow use these high performance designs and also provide the industry standard lifetime warranty.
cheers! mike
Old Jan 21, 2012 | 07:40 PM
DEE-AMG's Avatar
C300 BLACK
I want the car to have a nice loud grumble when stationary.
Once I put my foot down, would like it too scream but with as little rasp as possible.
I did intend to go full straight but worried the rasp will sound too much and also don't want it sounding cheap and jap racer style.
Old Jan 24, 2012 | 02:53 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
The size of the mufflers dont necessarily change the tone to a good sound. Its the chambering that controls the tone. If you get rid of the resonator and add decent mufflers it will sound great. No need to remove secondary cats, if it was an 8 cyl and u were doing full exhaust including headers yes pull cats. In our applications theres no need, and doing so causes lots of probs
