Squeak in coilovers ?
Old Feb 17, 2012 | 04:49 PM
hitokiri89's Avatar
2010 c350
Had them in for a bit now with no endlinks as I didn't get them with the set . Anyway endlinks are here just need to be installed but a few days ago I noticed a squeak coming from my rear coils . Is it just stress from no end links or dirt ? Or do I need to call the manufacturer ?
Old Feb 17, 2012 | 05:45 PM
Mixedfruits's Avatar
E63 Black on Black
anyhow you have megans right? Can you post your pic of lowest setting? I might be getting these as my next mod and need to decide if I want to get shorter coil springs
Old Feb 17, 2012 | 05:54 PM
Derek@MACAutoCouture's Avatar
Former Vendor of MBWorld
What kind of coilover? KWs are known for their squeek
Old Feb 17, 2012 | 05:55 PM
hitokiri89's Avatar
2010 c350
Sry bout that mixed I meant to on u back but the pm's won't send from my phone . Yeah I got Megan's . I'm only dropped an inch so I don't have any pics in lowest setting . From what my install guy said they can drop well below two inches . Also the ride doesn't suffer that much in comparison to other brands .
Old Feb 17, 2012 | 09:42 PM
bringtherain's Avatar
01' c320 (sold) / 03' Ford Focus(sold) :( / 98' C230 / 00' SL500 / 11' C300 Sport RWD w204
been wondering if i should pick up megans since i can't justify dropping over 2K on KW V3's and HR's dont have dampers. Good info!
Old Feb 17, 2012 | 09:49 PM
hitokiri89's Avatar
2010 c350
Other than the squeak I have no complaints . Might be hard to get a set now though as Megan racing told me I bought the last set in the country lol .
Old Feb 17, 2012 | 09:51 PM
i'll check with sonic and see if they kept some or only do on order basis. thanks for the headsup
Old Feb 18, 2012 | 12:49 AM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
The source of the squeak needs to be found. If the car is placed on stands, will is squeak if someone gets in the car and bobs up&down? As springs compress they rotate slightly, but on some lesser brands this metal against metal gets real loud, especially with CO's. Now it may also me the shock rod (or shaft). I have seen them also squeak as they are compressed down inside the shock body. The upper seal sometimes does this.
Try and locate the noise center and lube it with 100% pure silicone spray from 3M. Lube one place at a time, the try and generate the noise. Lube one place at a time until the squeak is silenced.
Had a set of Bilstein CO's that squeaked so much I had to sell them on eBay.
Old Feb 20, 2012 | 09:28 PM
Boris0126's Avatar
2009 C-300 Sport
Pics when you get a chance
