C300 Replace Brake Booster
1. Air leak sound when brakes not engaged. You can hear it over the engine idiling. Goes away soon as you engage the brakes.
2. Rough Idle and excessively rough idle with accessory load (power steering, acc).
I was thinking issue #1 was probably a brake booster leak. It wasn't till today that I realized #2 is probably the same issue. If there is a leak in the diaphragm then the engine would have a Vaccum leak.
I'm resonably mechanical, but I've never replaced a brake booster. Anyone have any tips for doing it on the C300? Is it a pain in the *** job? I trust myself for than my local dealership so if it's not to bad I'll tackle it myself.
Cheers guys.
Replacing the booster is easy if it's faulty.
Sometimes noise is just a ruptured boot where the pedal rod goes through the firewall. We had this on another car recently. Let me see if I can find the thread.
https://mbworld.org/forums/c-class-w...ghlight=brakes
Edit - and here is the other thread. Please excuse Ivanrad - he is non technical.
So from a noise perspective make sure it's not a bad boot. If it's a vacuum leak go further. If you are mechanical the booster swap is easy.
I was a little reluctant to work on the Benz with the lack of service manuals but a car is a car. The Germans can't build them THAT much different.
I have 36,000km. Pretty shocked I'm having to diagnose these types of things on a Mercedes at this stage.
Next step for idle is plugs. After that. I have no idea.
maybe get someone to run some star dianostic or try seeing if HQ will do warranty work out of good will.
I will double check though just to be sure. I'm not sure I mentioned it, but the rough idle/vibration is significantly worse in D on the brakes then it is in N or P. I'm assuming the engine is idiling the same either way but with the tranny in drive, it is just vibrating through the drivetrain more.
P.S Thanks Glyn M Ruck for checking back and following up.
Just like you described, it's horrible, when the engine is idling (warm at 600-700rpms) and I turn the steering wheel I get these strong pulses of vibration from the engine, seems like its from the load on the engine from the power steering. Exact some thing at a stop light in drive with my brake on I feel this vibrating strain on the drivetrain that goes away when put in neutral. When I am about to come to a halt at the stop light everything is smooth till I am fully stopped and I get a strong pulse of vibration from the engine for about 2-3 seconds and then from there on I just feel the smaller strain vibration. I took in in when it was under warranty for this twice and they didn't do anything for me. They said they checked the codes and saw no evidence of the "idle dipping" and they found nothing with power steering vibration, but now I'm out of warranty and it's there!!
here's my thread about it, Glyn had some good ideas which I mentioned it to my mechanic when having my trans fluid changed but he never really pursued it, soon I'd like to take it back to him and have him focus on it:
https://mbworld.org/forums/c-class-w...ping-halt.html -there's also some people that responded here with the same issue, one said they had their dealer "go over it with a fine tooth comb" and they found nothing.
It's nice to see I'm not the only one, I would love it if we could find a solution. This has been the only imperfection on how my car drives.
I see we have the exact same cars (08 c300 4matic), what kind of gas do you use? and has this vibration been there since you owned the car or did it develop?
edit: haha just realized your one of the ones who responded to that thread..
I've always used 91. I've only had the car for 6,000km though. Bought it used. I've tried to think back to if it existed when I bought it. I really don't think it did, but at the same time with a new car you're a little more wrapped up. You don't start to notice things like that till a month or two in.
Did your dealership just not have a fix or did they not even acknowledge it?
I've heard of that a few times, I've never had much luck myself getting the "Good will" treatment just out of warranty. Depends a lot on your dealer I'm sure.
The rough idle doesn't seek or dip like it usually would with a Vac leak either. Not ruling it out, but if it is a vac leak it's definitely not the hose connecting to the booster.
Regarding Glyn's idea of a vacuum leak on the air cleaner, I noticed my car (08) and I believe 09s do not have a metal clip in the back of the air cleaner that slides over it and locks it down (but the plastic stop is built into the cleaner for it), I did notice that the 2010 and 2011 cars have this clip. All it does is lock down the air cleaner. I know if it came this way from the factory in 08 and 09 it should be okay, but ot may be worth the try of getting the clip somehow.
Good luck!
Good luck!
Haven't had a lot of time to go much further, and I'm waiting on my plugs in the mail. Yes, I had to order Spark Plugs on the internet as noone stocked them.
What is your opinion on a sticky valve? I personaly would hope not at this mileage, but perusing around I seem to see a lot of talk about valve seating/sticking and idle issues for Mercedes engines.
As always though, you only see the negative on forums. Is it actually a common occurence on the M272 in your experience?
Easy check - Compression or leak-down test but I would not waste my time.
