Command DVD v.9 install
Old Mar 13, 2012 | 10:15 PM
Draz's Avatar
2012 MB E350 Coupe
Got ahold of a new map disc and I'm searching for info how to install it... I know the disc is inserted in tray 1, and you let it update by itself, while making sure that the head unit doesn't turn off.... my problem is that that my car is keyless so I can't turn key to position 1, my unit will turn off in about 20 minutes... Anyone knows how to do this, please help.
Old Mar 13, 2012 | 11:21 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Since the ignition must be on for the two hour update time, that means the engine must be running the whole time.
With my car sitting in my driveway, I locked it with the blade key and raised the hood to let the heat out.
You could do this while driving also, but you cannot shut down until it's through loading or you have to do it over.
Old Mar 14, 2012 | 12:40 AM
MoneyMike23's Avatar
'08 C350
Isn't the keyless-go button just a cover??? I think I just read the other day in the user's manual that you can just pop the push button off and use the key as normal????????
Old Mar 14, 2012 | 12:44 AM
'08 C350
Yeah... Page 85 in the owners manual says you can just pull it out.
Old Mar 14, 2012 | 07:56 AM
dgghostkilla's Avatar
2012 E350 4-matic SPORT
hey bro once your done with that dvd you should send it my way....
Old Mar 14, 2012 | 04:49 PM
Draz's Avatar
2012 MB E350 Coupe
Thanks for the advice... I did it while driving, didn't want to idle for that long... During the drive it did eject the disc twice, but when prompted I just put it back in... success
Old Mar 15, 2012 | 10:38 AM
coolvi's Avatar
2016 C63, 2009 C3004M
I just update it with the engine off for the first hour, and start the car for 5-10 minutes, then off again until it finishes. I do check on it from time to time and turn the key to "ON" position for a few seconds every 20 minutes or so. The update can be interrupted at anytime, though, and it will resume from where it's left off when COMAND comes back on.
I have done both the 7 and 9 updates the same way. No problems at all.
Old Mar 15, 2012 | 12:26 PM
aprince2die4's Avatar
08-C350 black/black
did you guys find anything new in the update?
Old Mar 15, 2012 | 08:58 PM
Draz's Avatar
2012 MB E350 Coupe
Nothing but new streets... and more details on the map, like gas stations & golf courses..
