Down shifting to slow down with automatic tranny.
Old Mar 26, 2012 | 02:33 PM
Waterloo c300's Avatar
c300 sport 4matic
When approaching a red light, I personally like to down shift even with my 7 speed automatic.
Is this hard on the tranny? I know it saves on braking.
I'm curious on what other drivers think.
Old Mar 26, 2012 | 02:48 PM
coolvi's Avatar
2016 C63, 2009 C3004M
I believe the 7G-tronic already does that and the calculation for optimal downshifting in deceleration mode starts as soon as you let off the gas pedal. It may not be as aggressive as you prefer, but I do feel that the MB's slows down noticeably faster than others without driver intervention thanks partly to this feature.
Old Mar 26, 2012 | 02:51 PM
Normandie4life's Avatar
Black C300
+1
Old Mar 26, 2012 | 04:17 PM
cswang's Avatar
2012 C350 Palladium Sport Sedan
Not sure how hard it would be if you did it constantly but I go by brake pads are less expensive to replace than a transmission.
Old Mar 26, 2012 | 04:48 PM
2012c350's Avatar
2020 C363 S / 2007 SLK55 / 2016 F150 4x4 / 1998 Cobra Convertible
Very much agree. Based on Glyn making some comment a while back that a tranny can cost $10KUSD I'd definitely not even consider it. Rotors and brakes are very cheap in comparison.
Old Mar 26, 2012 | 06:01 PM
LandSeaAir's Avatar
2008 W204
If you hold the shifter to "-D" the transmission will not only downshift once but go down to the lowest gear possible for optimal braking. I do this once in a while when I feel like it. It's cool it sounds like a manual when it jumps into 2nd gear and the RPMS pop up.
I do, however, agree if you do this excessively it can't be good for the transmission. I don't think rarely could be that bad though, if it was Merc probably wouldn't enable the feature.
Old Mar 26, 2012 | 07:01 PM
mhad2480's Avatar
2011 C300 Sport, 2007 Nissan Titan Crew Cab
I have noticed this occasionally as well, however I still downshift manually once in a while. The MB sales rep actually demonstrated this when I was test driving the car before I bought it, so I'd be curious to learn of any ill affects.
Old Mar 26, 2012 | 08:21 PM
tasho3's Avatar
2014 C63 Sedan
I manually downshift on daily bases, the car wont downshift sometimes in lower gear if its already on high RPM, so the trans won't do it unless its safe
Old Mar 28, 2012 | 12:20 PM
c300 sport 4matic
Interesting views on this....i would be very curious to hear the opinion from a SA on this topic?
Old Mar 28, 2012 | 01:56 PM
2012c350's Avatar
My sales rep had me beat the living snot out of the car I test drove. I certainly wouldn't take his advice on recommended driving style... I also wouldn't recommend buying that car if that's how all people were test driving it. (the one I drove.)
Old Mar 28, 2012 | 08:25 PM
mhad2480's Avatar
Fortunately I wasn't test driving the one I actually bought. I beat on the tester a little bit not too bad, not nearly as bad as when I test drove an STI. The sales guy was starting to get a little nervous there for a little while. The one I actually got was on the show room floor and they had to move two other cars to get it out.
