DIY, side markers
Old Apr 2, 2012 | 08:22 PM
kHuNkHuNa's Avatar
White 2009 C300 Sport
DIY, side markers
Step one - turn the wheel the opposite direction of the side your working on
Step two - peel back the liner from wheel well
- watch this video from 2:35, shows how to take out three pins, and peel it back
Step three - there is one clip on the top, push it down and out, and the light fixture should pop out
Step four - twist bulb, and pull out
Step five - put bulb in new fixture, lock it
Step six - put the bottom side in first, and push the clip in form the top
ALL DONE
Old Apr 4, 2012 | 04:49 PM
papashango's Avatar
This and that.
Thanks a ton. Will be doing that soon, so this will deff come in handy. Subscribed.
Old Apr 9, 2012 | 10:44 PM
bondj303's Avatar
C300
Side Marker replacement
Thanks for the great DIY instructions. I was able to successfully replace the front passenger side marker on my 2008 C300 without much issue! Took less than 20 min (didn't have the panel remover so had to make do with things I had and ended up using a 2 pronged fruit fork!!!).
Thanks again!
Old Apr 9, 2012 | 10:46 PM
kHuNkHuNa's Avatar
Originally Posted by bondj303
Thanks for the great DIY instructions. I was able to successfully replace the front passenger side marker on my 2008 C300 without much issue! Took less than 20 min (didn't have the panel remover so had to make do with things I had and ended up using a "2 pronged fruit fork!!!").
Thanks again!
"2 pronged fruit fork!!!" LMFAO - never tried that, i tend to use other items in the garage such as screw drivers and pliers,
but what ever works i guess
Old Apr 23, 2012 | 12:12 AM
Silverstreakc63's Avatar
2009 C63
Thanks. That video gave me a Kopfschmerzen. Only the Germans could make a simple lens replacement so complex.
Old Apr 23, 2012 | 12:16 AM
Karl09's Avatar
2010 c300
Why take it out when you can just tape around it then Plasti-dip it without taking it off car? MUCH MUCH easier...
Old Apr 23, 2012 | 12:58 AM
victort's Avatar
2010 C300
because not everyone wants to plastidip their side markers
Old Apr 23, 2012 | 12:59 AM
Karl09's Avatar
2010 c300
true that, hopefully no fix-it tickets are to come "/
Old Apr 23, 2012 | 11:42 AM
caligreenzzz's Avatar
W204
i dont think any pigs would give a ****.....
Old Apr 23, 2012 | 09:57 PM
_timothy's Avatar
c63
thanks for the pictures. i just did mine but i went in through the hood. after fiddling with the fixture i finally figured out how to get it back in there.
Old Apr 24, 2012 | 01:19 AM
pnoyworx's Avatar
10 E63, Sold -07 E63
thanks for your input, and effort to post. Been debating if I will be doing this or not. I think I will but with a amber bulb.
Old Jun 13, 2012 | 10:45 AM
fattysnax's Avatar
'09 C300 Sport 4Matic Arctic White
kHuNkHuNa, regarding step 3, that little clip that holds the side marker assembly together is really really tight.
Is there a trick to popping it out? I pushed down till my thumbs were sore and no luck!
Old Jun 13, 2012 | 06:30 PM
kHuNkHuNa's Avatar
push the clip down and outwards, it should just pop out
Old Jun 14, 2012 | 09:44 AM
fattysnax's Avatar
That's exactly what I've been doing. Had to brute force it out in the end.
Even with the assembly out and in my hand, that little tab was jammed really tight. Was simply impossible to remove while still in the wheel well.
That was the drivers side. Here's hoping the passenger side is as easy as you've been saying!
Old Jul 23, 2012 | 12:21 PM
River City Sol's Avatar
2010 C300 4matic
Side Marker Replacement
Folks I am replacing mine to the clear ones on my Black C300. Problem I'm having is that I can't seem to get it to fit tight along the bottom corner towards the wheel. I can't seem to get it aligned so that the tab pointing down that locks in in place will align and grasp again. Top and bottom front corner are fine. Its not the marker because the amber is the same now. Any advice from others who may have run into this. I've had it in and out many times to no avail.
Old Nov 7, 2012 | 12:41 PM
aamirani's Avatar
2011 C300 4MATIC
My sidemarker will not pop out. I have been pushing and my thumbs and fingers are sore. It will not budge. I have been pushing the clip down but it will not pop out.
Old Nov 7, 2012 | 01:44 PM
kHuNkHuNa's Avatar
i ran into none of these issues, so i cant say. hoping some one else can help out
the side markers where a bit tough to get out, try pushing it all the way back in and staring over, make sure theres nothing in between the clip that u have to squeeze in order to push out? other then that i really cant help sorry
Old Nov 7, 2012 | 06:35 PM
aamirani's Avatar
2011 C300 4MATIC
I figured it out. There is a bolt holding the back and front side marker pieces together. It's a star piece. If requested, I can go figure out what size exactly.
Old Nov 7, 2012 | 06:41 PM
aMsupp's Avatar
C300 Sport
You should just push down the clip and then force it toward the outside of the car. Half of the sidemarker will break free. Then there are 2 hooks on the bottom - just lean the sidemarker to the "outside" of the car and pull up and the hooks will release.
No bolts should be necessary to remove these unless they changed it in 2011.
Old Nov 7, 2012 | 07:05 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
There are some models that have this bolt. The housing themselves show the hole for the bolt, but some owners have reported having the bolt and some do not (mine didn't). We didn't bother doing any statistics to see if this was due to where the vehicle was assembled or some other cause, but model year did not seem to be one of the reasons as there was reported cases of cars with and without the sidemarker screw for nearly all years.
Old Nov 13, 2012 | 02:35 PM
Bhayes547's Avatar
2009 C300 4matic
Will be doing this soon. Thanks.
Old Dec 31, 2012 | 07:39 AM
Philippou's Avatar
W204 c300
Thanks for the thread bought my smoked ones and will be doing it next week
Old Jul 28, 2013 | 12:01 AM
mmike's Avatar
'10 C300
mine did have the bolt that holds the inner piece and the outer sidemarker piece together. i have a MY10 car. you need to remove the bolt in order to remove the orange sidemarker piece. i used a torx t15 i believe
Old Jun 27, 2015 | 10:34 AM
rentzington's Avatar
2010 C63 P30
Worked great in mine, hardest parts aligning that bottom tabs with such little room
Old Aug 22, 2015 | 12:59 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Excellent. Thanks for the write up.
This is my next job.
