wheel size question
Old Apr 3, 2012 | 07:23 PM
sdchrisc's Avatar
c300
wheel size question
19x8.5 all around with 45 offset lowerd all the way on h&r coilovers... will i have problems? what tire size would work best with this setup?
Old Apr 3, 2012 | 07:44 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
235/35/19 and u will clear no problem. If you wannt rotate tires its a good setup just dont get directionals or u will have to unmount to rotate, something that is often overlooked
u could also run a small spacer out back to get a staggered look if u wanted. 3 or 5 mm will work fine and be real close
Old Apr 3, 2012 | 09:05 PM
sdchrisc's Avatar
c300
awsome thanks!!
