Race Ramps in stock
Former Vendor of MBWorld
Race Ramps in stock
We also have some good ramps for the DIY'er out there. As you can see you drive your car up these 2 piece ramps and then you can remove the ramp to give yourself more space to get under and work on the car.
These 67 inch Race Ramps XT have a gentle, 10.75 degree angle for your low clearance vehicle -- but don't let that "gentle" stuff fool you. Our solid core design ramps are the toughest around, supporting up to 3,000 pounds and tires up to 12 inches wide. Whether you've got a Corvette or other low clearance vehicle, this low profile car ramp will get the job done. The 67 inch Race Ramps XT are ideal for oil changing, car detailing or other routine maintenance. Expect to be surprised, because you won't believe how easy it is to drive up our ramp.
These lightweight, low profile car ramps easily lift your car 10 inches off the ground, but they weigh only 15 pounds each, meaning that doing maintenance on your low clearance vehicle won't be the usual chore (no more heavy blocks of wood!) Most of all, our 67 inch Race Ramps are safe and Unscootable, hugging the ground and never slipping or sliding no matter what the ground's like -- grass, dirt and yes, even ice!
PRICE-$352.00/pair
![](http://i1027.photobucket.com/albums/y334/RPMNorth/RaceRamps%20RR-XT-2/rr-56-2-MAIN.jpg)
![](http://i1027.photobucket.com/albums/y334/RPMNorth/RaceRamps%20RR-XT-2/rr5621.jpg)
PRICE-$352.00/pair
![](http://i1027.photobucket.com/albums/y334/RPMNorth/RaceRamps%20RR-XT-2/rr-xt-content2.jpg)
