Tail Light Bulb Help
Old Apr 13, 2012 | 09:55 PM
papashango's Avatar
This and that.
Hi guys, need some urgent help here.
So I was driving today and suddenly I got a message on my cluster saying, 'check left side tail or brake light'. When I did that, I noticed the brakes were working fine.
I then turned the light knob all the way to the right and pulled it out all the way so as to first turn the front fog lights and then the back lights and noticed that my right rear tail light wasn't working.
I am just wondering why is the instrument cluster saying, it's left when it's actually right that doesn't seem to be working?
Also can someone please help me and tell me what kind of bulb would go there? And would I be able to replace it myself? Is it an easy enough DIY to change the tail light bulbs? If someone could kindly direct me towards where I can find that DIY it would be great. I want to do this within a day or two before I leave town so urgent help is needed.
Thanks a ton in advance.
Old Apr 13, 2012 | 11:20 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
You do know that there is only one rear fog and it's on the left? It is the upper half of the left taillight using the same filament.
Old Apr 13, 2012 | 11:31 PM
papashango's Avatar
This and that.
How would that make sense though? It looks weird in the back when I pull out the knob all the way and turn those lights on. Left works and is bright, right is still on but not bright at all and seems like its burnt out.
Also the error sign popping up on the cluster instrument...? Brake lights work fine and the other lights that are always on work fine too. Only one seems like its missing is that when turned on.
Old Apr 13, 2012 | 11:33 PM
global33's Avatar
2011 C300 4matic sport
There are three tail/brake bulbs per side. Any one of them could be burned out. Check your owner's manual how to replace a bulb and what type it is. (If you don't have an owner's manual you can find an online version on MBUSA.com) The bulbs are arranged on a pallet that you can remove once you open the compartment in the trunk. Any auto parts store will carry the bulb you need. Easy DIY. And, as stated, there is no separate fog light, only extra voltage to the left side bulbs when "fog light" setting is selected, so there is nothing wrong with the right side in your case.
Old Apr 14, 2012 | 12:15 AM
RLE's Avatar
RLE
There are three bulbs (Osram 12V 21W single filament) per side providing tail and brake light functions. Ignore the backup light bulb and the little side marker bulb for this discussion.
Those three bulbs normally operate on a reduced voltage, not 12V. When the rear fog is selected, the uppermost light is switched to full 12V, becoming bright, it's normal condition if used elsewhere such as in the backup light socket.
When the brake pedal is depressed, the two lower bulbs (lower tail lights) are switched to full 12V, becoming bright.
Therefore, there are three taillights but only two brakelights which are in the lower half.
Since the rear fog is working, and if a bulb has truly failed according to the lamp out indicator, it has to be one of the two lower bulbs which will be revealed when the lamp holder is removed from the lamp assembly. Another thing to check is the sockets since there have been reports of corroded sockets causing the bulb to become intermittent and this can light the bulb out light, also.
All this voltage switching is provided by the rear SAM.
So when any rear light function is selected, it's really done by sending a signal to the rear SAM from a switch elsewhere.
Old Apr 14, 2012 | 01:01 PM
papashango's Avatar
This and that.
That makes a lot of sense. Thank you so much, really appreciate it. It's pretty much what the service person told me. He said it's an easy DIY and can be done yourself, or he said they can do it and it will be like $30 roughly. Is there a DIY anywhere that I can follow that would show me how to pull out the brake light pallet and have a look. Once I know which bulb is burnt out, I can go to Canadian Tire and pick that bulb up and replace it.
Old Apr 14, 2012 | 08:49 PM
RLE's Avatar
RLE
The light panel has two latches, top and bottom, which protrude from the panel. You will see them with a flashlight. Push the top one down and the bottom one up a bit which will release the panel. To remove it from the car, unplug the power plug at the bottom first but to test the bulbs to find the bad one you will have to leave it plugged in. If you have OE LED turn lights, the two light gauge wires need to be unplugged from the panel first. Notice which wire goes where.
This is much easier than it might sound.
Old Apr 15, 2012 | 12:22 AM
papashango's Avatar
This and that.
Thank you so much. I was able to figure out when the guy at the dealership showed me. That was probably the easiest DIY ever. Thinking of putting LED bulbs in there now, just cause how easy it is to do. lol
