Ticking noise is driving me crazy.
OK. An update. I took out the glovebox and felt around while someone else drove the car. I could hear the noise coming from the interior near where the windshield and the body meet. I can't find anything that is making the noise or exactly where it is coming from. So despite all that I've taken apart the noise is still there.
If anyone figures it out, let me know in this thread.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
2009 c 300 Sport. mars red.
There is a ticking noise that is coming from the right(passanger) front corner near the A pillar that is driving me crazy.
The noise occurs at slow speed usually.
I removed the A-pillar cover and made sure the metal clips that hold it in weren't making the noise.
I actually am driving around with the A pillar cover off but the noise seems to be coming from under the metal grill on the top of the dashboard.
Any way to access that area? I've tried pusing felt into the corner without any change.
Also, when it is hot outside, the noise lessens or disappears.
And, it seems like it is transmitted via the airbag wire that runs up from the dash.
Can anyone help me?? Please!!
I found the location of the rattle, but am unable to reach deep enough to locate it or stop it. Theres some loose metallic piece (maybe a long rod) moving around between the windshield and the dash. I've only been able to suppress the noise by applying felt tape to a piece of rubber that is next the source of noise. It applies pressure and keeps the piece from moving around too much, but it still manages to rattle on extremely bumpy surfaces. I don't really know how else to approach the situation because I can barely fit my fingers between the windshield to tape down the rubber, let alone find the source. I'm just trying to find better tape with stronger adhesives while pairing that with different techniques to taping the rubber.
The windshield has not been replaced.
Domm, good to know. I still have the a pillar cover and the metal(or plastic grill) off and I'll feel around. I fell the rubber that you're talking about but can't feel anything else. I couldn't supress the noise when I was pushing down on the rubber. Strangely, on really bumpy roads, the noise doesn't occur. It only seems to occur when there is a small gap or bump on a relatively smooth road.
Try lifting the rubber and pushing it towards the dash to see if it makes the noise. I had to tape the rubber up so it no longer contacts the windshield. It's kind of hard to explain.
Also, when trying to put the A pillar back into place, you can pull the insulation around the area where the A pillar meets with the dash to create space. The A pillar will slide in easily after that and the insulation can be pushed back easily.
In my case, I don't think it is the rubber because it becomes quiet when the interior is hot. What I did was stuff a felt cloth in between the rubber and the windshield and the metal under the rubber. We'll see what happens.
#32
