A/C Blower slows down when braking
Old May 31, 2012 | 10:35 PM
Mercho82's Avatar
2008 Mercedes C350
Hey guys, yesterday I had my A/C on in manual mode and in two occasions when I pressed the brake to slow down in traffic the A/C Blower slowed down (like when you put it in 1 bar) for 2 secs and then came back to the normal speed (4 bars in the display). The blower display never changed it kept showing the 4 speed bars. This happened in a 2008 C350...
BTW, it was normal braking not a sudden stop or anything. Has anyone experienced this or knows what the problem could be?
Thanks Guys
Old Jun 3, 2012 | 01:09 PM
Mercho82's Avatar
2008 Mercedes C350
Old Jun 3, 2012 | 06:10 PM
ggms16's Avatar
2009 C300 4Matic Sport
Thanks Guys
Happened to me as well, a couple times.. Doesn't bother me too much to care about it. And in my case is not 2 sec, is like 1 second max.
Old Jun 3, 2012 | 11:35 PM
acr2001's Avatar
2012 C300 4Matic
If it is significantly slowing down, this is most likely a problem with your alternator (not generating enough power at idle RPMs). Does this happen when you have a lot of accessories running? The rear defroster in particular draws a lot of power. You might want to go into the 'dyno mode' menu to have a look at the voltage / amperage when it happens. If your alternator were to really bite the dust, you should get a red message in the instrument cluster though. I have noticed a very SLIGHT slow down in the fan when braking if I have it on full and many accessories running (this is pretty much normal).
Old Jun 3, 2012 | 11:50 PM
Mercho82's Avatar
2008 Mercedes C350
No, I didn't have any accessories running, not even the radio. That's basically why I could hear that the blower kind of stopped or slowed down for 2 secs.
