Changing the Final Drive Ratio
1. Available gear sizes: Even if it is possible to swap gears, what would fit it and what sizes can you upgrade to? I'm sure Mercedes has common components, but they may use the same gears which does us no good. But that leads me to my next point...
2. Commonality of components with Chrysler: The current gen of C class began development while Daimler-Chrysler existed meaning that there may be Chrysler components (or aftermarket) parts available.
3. 4Matic: With a front and rear ring and pinion upgrades, that means double the cost. You RWD types might have it easier.
4. Speedo: This will definitely need to be recalibrated, but I don't know how our current ones work. Again, classic cars you run some calculations and change a gear for a mechanical speedometer, these are probably different.
5. Cost: Says it all.
6. Performance changes: Quicker off the line, but lower top speed. Who really will use all 155 speed-limited mph? I checked the gears on the 7G and it shouldn't hurt highway cruising too much.
Again, I want to foster a discussion to see what others think. In the end it may be a total waste of time, but if it's worth a shot, I want to try it.
An option may be to go with 16" wheels and a significant changes in tire OD. I did this on tracked car #2, and it was amazing how much quicker the car was, like how hard it pulled in 3rd and 4th vs before.
"It'll give it the low end pep that I desire without drastically affecting the engine."
That may be solved with the Sprint Booster.
I've been trying to research the 4th Gen 4matic setup online but haven't found too much in terms of actual technical details. This is something where I'd definitely need to talk to Mercedes service to see if they have more info.
3.67:1 vs 3.92:1
Not a big difference, but this plus some ECU/TCU tweaks or maybe a higher stall torque converter should make a fun car. I’d be happy if it makes 0-60 less or equal 6 seconds.
