Why is Mercedes engine efficiency trailing?
What really shocks me is Hyundai Sonata's 2.0 T getting 22 MPG city and 34 highway while putting out a whooping 274 horsepower and 269 ft/lb torque.
Not like the C class is much heavier than the Sonata. What gives?
What I'm curious about is how this feature affects 0-60 times. When magazines test, are they able to disable the feature...or does a "brake-stand" cause the engine to start back up even though the car isn't moving? I assume so, otherwise there has to be some lag in performance from starting, engaging the transmission, and going.
This is not the reason why other engines/manufacturers are more efficient.
I think most of the Merc engines still use some outdated technology. Are any engines in the current lineup full direct injection? Maybe the 1.8 turbo but compared to that both the Audi and BMW have much better engines, fuel economy and power.
Love the sound of the 3.0 V6 though. I think Merc will have to deliver an engine that compares to the other 2.0 Turbos. My guess is that they are working on it. I don't really care because we did not buy the car for its consumption numbers but I love the 2.0T I also have in my VW.
The issue is that it simply doesn't work very well for spirited driving, unless you drive like a comatose Honda owner that is... that's where it shines. The car would hesitate after restart from a stop light, then jerk and pulsate, even surge and hop as it tried to accelerate from a DEAD, and I do mean an engine dead stop. Not my cup of tea... and surely it would eventually wear down the starter motor, not to mention the additional internal friction during the winter months since it does not keep the oil pressure up during shut-down.... it's a crappy idea IMO meant to get THEIR mileage numbers up, (bragging rights) and then your money after the warranty expires from all the added friction related repairs this system will probably cause after 5 years.
No excuse for such a modestly powered car as the C250 to not be able to do better.
Then you have the matter of how accurate the tests are vs real world usage. Mercedes-Benz has long stood by the belief that they build their cars for the best real-world application, despite test results, this is especially true for safety, as well as fuel economy. In fact, you will find that Mercedes typically under-publishes their figures for EPA estimates and horsepower, which explains why 4matic models maintain the same estimates as RWD models, despite the extra drive train loss and added weight.
When you consider the fact that I easily achieve over 31mpg highway, and with my intake and tune received as much as 42mpg overall (not just highway), and if you read edmunds consumer reviews for people who own the sonata turbo, many complaints surround the poor MPG where they receive roughly half of the EPA estimates.
Do I think mercedes-benz is at the forefront of new technology? No, but I also think that they have a reputation that they do not want to tarnish, and will not just jump into new technology without learning of the many repercussions. Take Direct Injection for example, many of the early adopters for direct injection from BMW, Audi, Porsche to virtually most other early adopting brands have had HUGE issues with Carbon build-up on their direct injection models, and have since revised their designs, but not before screwing customers over needing expensive engine tear-downs just outside the warranty period, leaving thousands of owners filing class-action lawsuits.
About the only regret I have with the C250 are the HP/TQ ratings versus other manufacturers. With that said, I'm sure that they didn't go for a bigger turbo or allow higher boost in the engine due to reliability and to ensure the classic mercedes-benz longevity. None-the-less, I wish that they could have done a little bit "better".
Either way, I'm very satisfied with my vehicle, and even though it doesn't have the power nor fuel economy of other vehicles, the c250 drives MUCH better then the sonata, and overall I think is the best vehicle that caters to my tastes and needs.
500 mile round trip this weekend - 28 mpg.
15 miles trip to work - Can achieve over 30 mpg.
Firm believer of the right-foot theory on miles per gallon. Takes out all the confusion.
Running in lean burn mode with poor fuel can lead to driveability issues such as engine stumble & flat spots.
Benz will never knowingly put a car into a market that has driveability issues. They will err on the safe side which means higher fuel consumption.
Vehicle weight is also a factor in the issue being discussed.
Benz always builds & tunes for longevity.
About the only regret I have with the C250 are the HP/TQ ratings versus other manufacturers. With that said, I'm sure that they didn't go for a bigger turbo or allow higher boost in the engine due to reliability and to ensure the classic mercedes-benz longevity. None-the- less, I wish that they could have done a little bit "better".
Out on the highway, the turbo 4 pulls high 20s without really trying if you drive it reasonably.
But again, it should be. It has a 73 horsepower advantage. It also uses regular fuel.
Also what's this about the C250 being "a good 350lbs heavier than the Sonata"?
It's actually about 137lbs heavier.
Still though, you'd expect a 1.8l 4 cylinder with direct injection to get better mileage than that. Like a lot better. 25 MPG city and 35 hwy is probably a good standard for a 2012 car with that kind of engine.
There must be a reason for this?
First of all I know all UK figures are different as we are basing economy on a UK galloon but that's not the point.
Here in the UK the c class economy is fantastic. Bear in mind here we use mainly diesel variants. (200/220/250 being the most common).
The 2012 250 CDI is quoted (from mercedes website)
Urban 47.1
Extra 68.9
Combined 58.9
The 2012 350 CDI:
Urban 39.2
Extra 54.3
Combined 47.9
This is a vast improvement on the pre-facelift model and in fact the 3L V6 diesel is, looking at the combined figure, just about as economical as a ford fiesta zetec s. (A commonly used sporty hatchback).
My 2009 C200 CDI is actually cheaper for me to run than the hatchback I used to drive.
Brett
