How to fix interior scratch?
Hello,
Does anyone know how to remove scratches from interior trim pieces? I recently noticed a very small (less than 1/2 inch) scratch on the trim piece surrounding the gear changer (between the gear indicator and gear change lever). You can only see it in direct sunlight, but it still bothers me. I've searched and only found methods for removing scratches from black textured interior panels, but this piece is a bit glossy and is not black. Methods I found through googling include using a heat gun or hair dryer to heat the area and rub the scratch out or using a wax infused plastic cleaner to fill in the scratch. Has anyone had any experience with either method? Thanks in advance for any help.
