Roof Spoiler Fail???
Old Jul 16, 2012 | 04:55 PM
12_benz's Avatar
c250
Well, I ordered a really nice painted roof spoiler, and went straight to the auto body shop to buy genuine 3M to install it. I even used the adhesion promoter. It only held a couple days and then one side started to lift. So, I thought back to when I had my BMW and I bought a roof spoiler from Bimmian.com and they included Pertex A6000 adhesive (worked fine before). So I found some, cleaned the spoiler and glass, applied the adhesive and things looked good. Even this morning after 36 hours of sitting still, everything was ok. Well, after lunch I checked it out and the darn thing is coming loose again? I don't think I will be able to get it off without destroying the spoiler though? I think the overall contour of the spoiler was just off and it wouldn't lay flat no matter what??? Take a look...
*This morning that was completely flat and flush to the glass.
Old Jul 16, 2012 | 06:58 PM
1DarkChaos's Avatar
2008 C300
return the roof spoiler or get a exchange
nothing to do with adhesive, just badly molded spoiler
Old Jul 16, 2012 | 09:54 PM
chewychiu's Avatar
2013 GL450
Did you heat up the 3M tape first? That usually helps it stick better. Good luck.
Old Jul 17, 2012 | 02:35 PM
Petje's Avatar
W205 C400
Think you can better use Silicone glue / sealant (dont know how to call it the right way )
Had done my prev car roof spoiler and had the same prob.
Carlsson always deliver this with the roof spoilers .
Old Jul 17, 2012 | 02:45 PM
12_benz's Avatar
c250
I'd love to know what others have used that worked?
Old Jul 17, 2012 | 02:54 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Most likely the air vents underneath are either covered or blocked. This will promote warpage of the wing as the air inside and the wing heat up.... causing it to twist and lift. No glue will help that.
Old Jul 17, 2012 | 02:58 PM
12_benz's Avatar
c250
That's an interesting idea? If you use an adhesive wouldn't it pretty much seal out air from the center? I thought those holes had something to do with the molding process?
Old Jul 17, 2012 | 03:06 PM
MBRedux's Avatar
Yes, these holes serve both purposes. Did you cover them up? Leaving one open should do the trick. But is the wing plastic or fiberglass? Plastic will twist more than fiberglass will. Sadly, your wing may be permanently damaged, as heated plastic tends to "remember" it's new shape once warped no matter how strong the adhesive.
Old Jul 17, 2012 | 03:16 PM
12_benz's Avatar
c250
Well, it's ABS. I bought it from one of the vendors on here. It doesn't seem to be that far off when aligning it on the back glass, but maybe that 1/2'' or so that it needs pushed down to be flush in the culprit? It was like that when I got it, and the double sided tape nor the A6000 seems to hold it?
Old Jul 17, 2012 | 04:12 PM
MBRedux's Avatar
Send it back. It was made wrong from the beginning. ABS plastic will warp even more when heated as it expands. Trapped air will not help either. Try and get them to replace it. Just explain your situation. Worth a try.
Old Jul 18, 2012 | 01:36 PM
12_benz's Avatar
c250
That's what I am going to try to do.
Old Jul 18, 2012 | 09:54 PM
aowhaus's Avatar
2008 C300 Sport 4matic
I used 3M VHB tape on my roof spoiler and it has held up reasonably well.
I used a very wide tape (I think either 3/4" or 1" wide) and covered about 80-90% of the surface of the spoiler underside.
The ends has lifted slightly over time (about 1/8" gap at the most) and the tape has lost some of it's adhesive strength after being exposed to the elements.
I just replaced the 3M tape at the ends (about 6" to 8" of it) about once a year.
I don't think my spoiler had any vent holes in them and it's plastic.
Old Jul 27, 2012 | 09:24 AM
12_benz's Avatar
c250
Well, no luck. I think when you buy knock off parts you run this risk. Paint quality was great, but fit obviously wasn't. I would just caution others from ordering this item from JBSPEED.
Old Jul 27, 2012 | 01:50 PM
MBRedux's Avatar
That sucks! I will never buy from JBSPEED in that case!
Old Jul 27, 2012 | 02:09 PM
Sportstick's Avatar
Another round of ICE
An unfortunate turn of events. I think most of the history on this forum will show good experience with JBSPEED. The spoiler I bought fit perfectly and the paint was spot-on. He had been very good about customer service. Try communicating with him before giving up. It could well be that he got caught by surprise by a quality issue at his supplier.
I have been in the minority, but I have long been railing about not relying on 3M tape, based on my experience with adhesives in the auto industry. My deck and roof spoiler are both attached with a bead of urethane in addition to the tape. Those spoilers will not dislodge.
