Can i replace OEM halogen headlights C180 (2013 )With Bi-Xenon OEM of C250 ?
Old Mar 17, 2015 | 04:59 PM
Grafium's Avatar
w204 c300 model 2008
thanks a lot for all your help, i really appreciate it.
one small thing, to adjust manually, i located easily screw number 2. but i could not find screw number 1. it looks like its covered with plastic !!
thanks for your reply.
Old Mar 17, 2015 | 05:03 PM
Szelas73's Avatar
'11 Merc C300 4M, '15 ML350 4M
Originally Posted by Grafium
this is the result of the installation
Looks great! Did you end it up installing capacitors? Did all pins from my schematic worked out? Let me know
Old Mar 17, 2015 | 06:04 PM
Grafium's Avatar
Concerning the manual adjustment, i only could find one screw, the other location it totally closed with plastic, no screw is showing ( location 1 on your schema)
any idea ?
Old Mar 17, 2015 | 06:08 PM
Grafium's Avatar
no i did not install capacitors, no need, we just had to initiate the car to recognize xenon onboard ( by scanner) and all went smooth. thanks a lot.
still have the issue of manual tuning, but i cannot find screw on location 1. its hidden
Old Mar 17, 2015 | 06:09 PM
Szelas73's Avatar
any idea ?
Yes, regular (non bi-xenon) halogen headlights assemblies have only one screw, bi-xenon assembly have two, so it looks like you just did xenon kit installation on your original headlamp, right?
Old Mar 17, 2015 | 06:13 PM
Szelas73's Avatar
What I have done is: I did remove my original halogen headlamps and install headlamps from C63, that way I am not going blind incoming traffic...
Old Mar 20, 2015 | 03:15 AM
  #32
Grafium's Avatar
No, i replaced by headlights completely by Original Bi-xenon headlights from a donor car too. they are genuine MB Bi-xenon headlights. the highbeam is turning the middle highbeam on and opening the flaps of the Bi-xenon too.
anyway , i ll check what the screw i have is doing, i think it should be enough if it s the up-down level.
Old Sep 26, 2019 | 08:47 PM
  #33
Bouncer-01's Avatar
2010 Mercedes C Class C200 2143cc diesel
Hi mate, any chance that you could help me? I'm trying to upgrade from 2010 C Class Halogen Headlights to Bi xenons headlights from 2011 sport C class, halogen lights connector (yellow) has 10pin with 10 wires and Bi xenons has 14pin with 9 wires going in, I just wanna cut the cables from 10pin and join them to the 9 cables coming out from 14pin connectors, getting confused with wires colors also where i'm suppose to install capacitors? Best regards.
Old Sep 26, 2019 | 08:55 PM
  #34
Bouncer-01's Avatar
don't know if did the wiring right or not but im just getting left and right parking light faults? and C lights doesn't look bright enough? any help much appreciated.
