Door Pins Question
Old Jul 27, 2012 | 06:59 PM
1DarkChaos's Avatar
2008 C300
Question Door Pins Question
Hello there, I am just wondering if the rear doorpins are different from the front?
I understand from research that the front is removed by twisting and the back is removed by pressure, so does that mean that they are different in length and in the diameter or are all 4 exactly the same
Thank you and take care!
Old Jul 27, 2012 | 07:56 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
The rear pins are shorter and do not taper as much at the bottom.
Old Jul 27, 2012 | 07:59 PM
dfordham's Avatar
2014 E350, 2012 SL550
Yes, the fronts are threaded and the rears are press fit. The fronts are easy to change out but be careful with the rears. If you press too hard you may lose the rod they are fitted on, and you will need to remove the door card.
Regards,
Don
Old Jul 27, 2012 | 08:35 PM
Sportstick's Avatar
Another round of ICE
Read this:
https://mbworld.org/forums/c-class-w...door-pins.html
