Hope for the LAME 722.9 7G transmission
2016 A5 2.0T 6-speed, 2012 C300 Sport
Yes, it's called pushing the "S" button. The transmission is horrible in "E," but it's fine (if still somewhat slow) in "S" (even if it seems to degrade fuel economy).
If you're finding that maneuvers in "S" are still "outright dangerous," then perhaps you should consider that the maneuver you are attempting is simply ill-advised.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Some bright programmer just needs to develop an EPROM flash for the TCU that switches out the learning & make S Mode constant hold revs & quicker change while W or E mode remains lazy, early upshift for fuel economy, start in second unless you go WOT when it should start in 1st as it does stock.
2012 C250 Sport
Wonder why our experiences are so different. =( Do any of the other posters have a possible explanation?
2012 E550 Sport Coupe, Capri Blue w/Almond Leather; 2005 Lexus IS300; 1983 Mercedes Benz 380SL
Get the TCU reset to factory, then punch it
My 2009 C350 Sport suffered from what you describe. It would shift into 3rd gear at 20 mph at 1200 rpm. I tried to get the adaptive logic to adapt to me to no avail. It was apparently driven by a grandma before I got it and didn't want to learn new tricks.
I took it to the dealer I bought it from and asked to have the TCU reset to factory specs. Then I went to a little-traveled straight road and drove it like I drive for the first 40-50 shifts in "C" and for the first 40-50 shifts in "S" (each mode has its own adaptive memory). Depending on pedal pressure, it's now shifting at about 2000-3000 rpm in "C" and 3000-4000 rpm in "S". If I really punch it in "S", it'll wind out to 5K+.
I am very happy with the dramatically improved performance. Combined with the Kleeman ECU tune, this car now drives like a real sports sedan. No street racer mind you, but smooth and peppy.
Others can argue the benefits of Beemer vs. Benz. I'm happy with my car.
'11 MB C300, '93 Toyota Supra T , '12 Chevy Cruze
Before buying my car, I compared this C300 to a BMW and Infinity. The infinity G37 and the BMW 328xi were very joyful to drive. Peppy, fast steering, and not as refined as the C300.
IMHO, I went with the C300 Sport because of the lines and curves she has, and her subtle driving composure. Not too harsh of a transmission shift, smooth, elegant to drive. Plus, its my wife's daily. She doesn't care! To say that it is dangerous to drive? I doubt it. You must be a very impatient, adrenaline junkyed driver! I keep the car in "S" mode, and she holds gears longer, and doesn't shift as often.
This car drives like it should, and thus performs as it does. The BMW is more driver oriented, so perhaps those vehicles fit your needs better.
If you do perform the valve body modifications, or are able to adjust the transmission computer's shifting capabilities to more aggressive, let us know.
#32
I wanted to make a comment about "taking off in second gear". On my 7G when I would come to a stop I would get a jerk. Dealer tried reprogramming the TCU without success. Then they decided to change the Valve body to an updated one. It felt that the car comes to a stop on 2nd gear and take off in second gear.
I'm not a big fan of the 7G. It's tough because for 70k miles I beat the hell out of it and it's still running ok (knock on wood) BUT there is lag and takeoff sucks on the car. If not in manual mode when I floor the pedal from a dead stop I feel a downshift!! then it takes off.
I was never a fan of this transmission. It's great for comfort but not as responsive and sporty than a BMW transmission. But then again that's comparing apples and oranges.
I wish the transmissions on the Sport models were a little more sportier. But then again the car isn't a GTR![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
If I had an AMG I would definitely do the Weistec upgrade
bassfreak (05-15-2016)
