I think i found my next mod!
Old May 21, 2013 | 03:27 PM
  #101
nismosr's Avatar
2009 C300 Sport 4Matic
Originally Posted by kevin.vernal
anyone knows where I can buy the Red/Clear ones? I mostly see the smoke ones. Thanks
it looks like they are both out of stock.
Old Jun 11, 2013 | 07:02 PM
  #102
kevin.vernal's Avatar
2012 C63 ///AMG coupe
Red/Clear aftermarket 2012 tail lights
bought these for $235 directly from spec-d...I'm too cheap to buy the OEM ones... Anyway it's just plug and play with my C63 with lightning package... everything works fine.
Old Jun 11, 2013 | 08:32 PM
  #103
nismosr's Avatar
Are you hearing any buzzing sound when the lights
Are on?
Old Jun 11, 2013 | 09:14 PM
  #104
Are on?
Not that much when i cut the green with yellow thin line... It comes with a manual with that says
Old Jun 12, 2013 | 12:19 AM
  #105
CzchMex's Avatar
2010 C300
So cutting some wires will help hinder the buzzing noise? Are you saying that all the other people didn't read the manual??? Lol
Old Jun 12, 2013 | 08:40 AM
  #106
lol!!! when I had these on my C300 it doesn't come with any manual but this time when I got it I see there are big difference... When cut the wire instead of two thing looks like a AA batteries noises now its just one. Dont know WTF u call those s*** but here is the pic they change it... see for yourself.
Old Jun 20, 2013 | 11:20 PM
  #107
Jon89's Avatar
Mercedes c300
Does anyone have pictures of the red smoke ones installed on a red car? Would appreciate it.
Old Jun 21, 2013 | 12:40 AM
  #108
dolvio's Avatar
2010 C250 4Matic
Hey, where did you get these from and how much were they?
Cheers,
Adam
Old Jun 21, 2013 | 01:38 AM
  #109
Knightmare69's Avatar
2010 C200 CGI
Cheers,
Adam
Post 102
Old Jun 23, 2013 | 07:44 PM
  #110
dolvio's Avatar
2010 C250 4Matic
Do you still have to cut the green wire? Or have they fixed this problem?
Adam
Old Jun 23, 2013 | 08:13 PM
  #111
Adam
Its plug and play and its up to u if u wanna cut it... I cut it... Instead of both buzzing now just one.
Old Jun 23, 2013 | 08:15 PM
  #112
dolvio's Avatar
2010 C250 4Matic
I have a pair of these that I got for $125. No manual. Would you be able to explain further or scan the manual? Much much appreciated.
Old Jun 23, 2013 | 08:25 PM
  #113
Pm me your cell number ill take a pic of the manual
Old Jun 23, 2013 | 08:35 PM
  #114
dolvio's Avatar
2010 C250 4Matic
Pmd you!
Old Jun 28, 2013 | 02:49 AM
  #115
dolvio's Avatar
2010 C250 4Matic
I installed these aftermarket lights tonight. I must say they do not fit as nice as the oem\s and they do rub the paint a bit. As the car body panels move slightly, they paint will wear. I have had this happen on previous cars. I also didn't like the buzzing even after I cut the green/yellow wire. Just seemed like a mess of wires back there also.
Thanks,
a.
Old Aug 13, 2013 | 12:54 AM
  #116
Yamdan's Avatar
C220 CDI 2016
Hello
I just got these lights for my C63 2009 and of cause I got the buzzing sound but as well the message in the dash saying tail/brake light are broken! :-(
Did yours work strait away? Or did you need to do any modification?
The seller told me that they would work and they would modify them so I wouldnt get any mess. But that wouldnt work :-(. So to say the least Im so dissapointed with them right now. Sent the messages but havent heard anything in 8 hours.
Heeeelp!
Old Aug 13, 2013 | 01:02 AM
  #117
dolvio's Avatar
2010 C250 4Matic
Originally Posted by Yamdan
Hello
Heeeelp!
They are plug and play. Not sure if they work on a c63
Old Aug 13, 2013 | 01:11 AM
  #118
Yamdan's Avatar
C220 CDI 2016
They promissed that they would work on my C63. They even have that in their ad on Ebay! But I just think its some kind of modification they forgot to do.
Will be intressting to see if they will come through and get this fixed or if Im just ripped of
They aint exactly fast to answer on the emails.
Old Aug 13, 2013 | 04:06 AM
  #119
Yamdan's Avatar
C220 CDI 2016
Ok problem solved.
One wire that was not supposed to be cut was cut so I fixed that and I did cut the Green/Yellow and no message in the dash :-)
Just a little bit anoyed about the buzzing
Old Aug 13, 2013 | 10:39 AM
  #120
Ok problem solved.
Same here have a C63... Passenger side i cut the green/yellow wire but the driver side just left it didnt cut the wire... Had it for a long time still no issues...
Old Aug 13, 2013 | 10:57 AM
  #121
Yamdan's Avatar
C220 CDI 2016
I did cut it on both sides :-)
No idea what the diff would be... will have a closer check this evening and see/hear if its better now...
Old Aug 13, 2013 | 03:50 PM
  #122
Oh ok... When i cut the green/yellow wire just one stop buzzing but the other one still buzz
Old Aug 13, 2013 | 03:54 PM
  #123
Yamdan's Avatar
C220 CDI 2016
Well they both still buzz but its more depending on what they are attached to!
Old Aug 13, 2013 | 11:47 PM
  #124
dolvio's Avatar
2010 C250 4Matic
You can cut the green/yellow wire on both lights and it will shut off some of the buzzing. I accidentally cut the green/yellow wire in 2 places on both lights and I screwed them up. So I have to use a couple connectors to connect that wire back up. Works fine now. not sure how well these lights will hold up in the long run.
Old Aug 14, 2013 | 08:06 AM
  #125
nismosr's Avatar
when you get a chance can you post a picture of a night shot of the tail lights ? thank you
