Dirty air filter
Old Sep 23, 2012 | 11:35 AM
Ryan17406's Avatar
W204
Dirty air filter
I recently bought a 2010 c300 sport 4matic and it felt sluggish, so I took the air box off and found dirt n leaves... Wth... So I dropped in k&n for $80 from pepboys.... Fitting it together was a little off on the edges but got it together... Big difference from them old dirty filters...
Old Sep 23, 2012 | 01:53 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
Glad you got some power back.
I have not heard of anyone that did dyno work, or simple pressure drop measurements (that I have done on my tracked Rx7) for the oem system. Just a clean filter may very well have returned your lost power, with little help from the K&N filter.
Old Sep 23, 2012 | 03:03 PM
Domm's Avatar
'08 Mercedes C300
The oem filters do not attract more dirt than the k&n filter. The cause of the build up is probably due to neglected maintenance.
Old Sep 23, 2012 | 03:57 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I would not use anything else but oem. They are designed to do the job on this car. You are risking your engines longevity.
Old Sep 23, 2012 | 04:41 PM
Ryan17406's Avatar
W204
dirty filter
does anybody know what this secondary filter is for.. it was a fabric type filter inside the cover...the filter covers(1), filter(2) and mysterious filters(3)...
Old Sep 23, 2012 | 11:55 PM
Knightmare69's Avatar
2010 C200 CGI
Weird, it looks like the same material used for the cabin filter. This is the first time I've seen secondary filters. Even on the S-class v8's I never saw them when swapping out the filters. Must be a new thing. Is there a part number on them? You can prob cross reference them online.
Old Sep 24, 2012 | 12:09 AM
itsLoonie's Avatar
2012 E350 RWD
First time I've seen it too. Mine doesn't have that
Old Sep 24, 2012 | 11:39 AM
Ryan17406's Avatar
W204
It said Germany and sum number but I won't have it back for a couples days prolly cuz I sent it back to the dealer to look at te cats and cabin air filter cuz I get a rotten egg smell when I punch it to get on the highway... So I'll have them look into that also...
Old Sep 24, 2012 | 02:39 PM
kevink2's Avatar
There is only enough room for a pleated filter about 1-1/2" thick. When you put the K&N in, which old filter did you remove, based on the photo ?
Regardless, you need to clean the leaves out during and then after the fall, if you live where the leaves came from, or a similar "heavy" fall area, which includes York Pa. You could also devise a tacky, pre-entry screen before ea intake slot ... perhaps light 1/2" chicken fence screen.
Old Sep 24, 2012 | 05:07 PM
morph860's Avatar
2013 C300 Sport 4Matic
When I had my 2010, I pulled out all 4 of those filters before putting in the 2 K&N's.
