False Tail Light Indicator warning
Old Oct 2, 2012 | 12:56 AM
cire06's Avatar
2010 c300 sport, premium package 1 w/ command package
I recently purchased a 2010 c300. About a month after purchase the "check rear tail light " warning goes on every time i start the car. I've looked at the rear tail lights and they are all working properly. Is there a way to reset the warning?
Old Oct 2, 2012 | 02:49 AM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Your ground wire is probably starting to burn through the harness. Open the little hatch on the right side of your trunk and take a look at the 7 pin connector.
You can also look up my thread about the melted tail light connector.
Old Oct 2, 2012 | 01:57 PM
cire06's Avatar
Thanks for the help. ill take a look at it
Old Oct 2, 2012 | 09:29 PM
dcjwlee's Avatar
https://mbworld.org/forums/c-class-w...ml#post5379424
Here is the thread. THere is a post where a user had this repaired at no cost (good will) event hough he is out of warranty.
Hope for us all.
