Backup Cam flickering.
Old Oct 11, 2012 | 05:17 PM
xzotik1's Avatar
C300 AMG SPORT
Exclamation Backup Cam flickering.
I installed my new Backup cam today , but when I press the gas the picture flickers. This also happens when I turn the headlights on and off. I accessed a ground (brown) and a 12v(grey/yellow stripe) from the Tail light harnest. I used T-taps to tap in to these wires video cable is not pinched and all connections behind the radio are good.
What do you think is going wrong?
Old Oct 11, 2012 | 05:32 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
I used the accessary outlet, either the front or the back I forgot. the camera picture is solid, as clean as it could be, never had any issue over a year now.
Old Oct 12, 2012 | 12:36 AM
waiszeto's Avatar
GLK 250
I have the same problem before. Solved by order 12v plug from ebay and used the accessories plug in the gloves box instead connect the wire. Good luck
Old Oct 12, 2012 | 01:03 AM
benzmodz's Avatar
W203 slightly modified
install factory modulator
Old Oct 17, 2012 | 10:44 AM
icio67's Avatar
W204 C250 CGI Avantgarde AMG
Can you explain me more.... please
Old Oct 17, 2012 | 01:53 PM
ranorris2's Avatar
2009 C350
Could you give a part number for this?
What exactly does it do?
Old Jan 22, 2013 | 10:36 PM
xzotik1's Avatar
C300 AMG SPORT
I fixed this by connecting to another ignition triggered wire not from thr tail light harnest but from thr back of the fusebox.
Old Jan 23, 2013 | 12:48 PM
ONE-9-T's Avatar
W204 C350
but now the cam runs all the time.....its better u fix this whith a relay or somthing like this.....then it runs just if u set reverse gear.....
example:
