Where did I do wrong?
Old Oct 12, 2012 | 09:35 PM
rtai's Avatar
glk350
Unhappy Where did I do wrong?
I tried to clean up my air filter both C230 & GLK350 2 days ago. I thought it should be easy and common. So, I diy C230 first. I unscrewed the air house, took out the filters and blew the air into the filter. Actually, it was not very dirty. I would like to take this opportunity to figure out whether both c230 & glk350 filter are the same.
After the air house was set, I did the same on my glk.
The nightmare comes in the next morning, both cars are choked when I start the engine and the engine service light comes on the dash board.
I have no idea why and how this happened. I am pretty sure I didn't touch or remove anything except the air house.
The next day, I borrowed a code scanner and got P0172 & P0175 on my glk, P0170,P0015 &P0173 on my c230.
Is there anyone can tell me where did I do it wrong? Is there anything I can make up? I can't belive that I screw up.
Old Oct 12, 2012 | 10:51 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
This has been reported before when someone installs the air filter housing incorrectly. Take it off again and check the connection at the rear which leads into the mass airflow sensor. It's likely that the gasket is unseated.
And don't try to clean filters. If they are dirty install new ones.
Old Oct 12, 2012 | 11:18 PM
rtai's Avatar
glk350
Thanks man. Actually, I installed couple times already but kept the original filter. I purchased a pair of new filters this morning and get ready to put them on either one tomorrow.............
Now, you know that both their filters are the same type.
Thanks your reply.
