D2 coilovers
Old Nov 16, 2012 | 01:43 PM
Mixedfruits's Avatar
E63 Black on Black
oh and I took out rear spanners like I said.
Old Nov 16, 2012 | 02:24 PM
mangoango's Avatar
08 C350
How much lower was the car after you removed the rear spanners? Would you say half an inch?
If you remove the rear perch, how much lower will it be?
Old Nov 16, 2012 | 06:51 PM
E63 Black on Black
guesimate for rear is around a inch drop maybe more
for rear spanners I never measered before with them but also around .75-1 drop I think
Old Nov 17, 2012 | 02:01 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
Sorry, I forgot about that. The oem rear looks like a typical strut assembly:
So I thought the D2 would look the same, but with the adjustable lower perch. You removed the spanner-nuts (spanner is the special wrench to turn those adjustable nuts).
I thought the lower support for the rear D2 spring was the top nut, which is locked in place by the next nut down. If you removed both of these nuts, what supports the rear spring?
I thought the lower part of the rear D2 was similar to this random D2 pic:
Typical D2 kit
Old Nov 18, 2012 | 03:20 PM
wnunez89's Avatar
c350coupe, Gencoupe R-spec
nice stance!
Old Nov 18, 2012 | 04:09 PM
E63 Black on Black
it perch is holding it and the nuts are off the sack lmfao ill try and take a picture for you later. tires exploded on the freeway last night ripped my other side esp, asb, yada ya off so ima try and fix but :/
Old Nov 18, 2012 | 04:38 PM
  #32
wnunez89's Avatar
#StanceCarProblems
Old Nov 21, 2012 | 11:47 PM
  #33
IW IE IS IT IA's Avatar
2012 C Class
Very very nice!
Old Nov 22, 2012 | 02:05 AM
  #34
E63 Black on Black
#loweredlife but on the real found out a solution since my rears have no fender liner wires such as my esp/abs/cruise sensors are easily out and hanging and thus ripped. I am going to buy new sensors soon price is ~200$ what a set back. But drill two holes around the size of a dime or a quarter to the fenderwall going into the car and run a rubber mesh/cover and run the wires through the holes. Mods to come aha
Old Jan 3, 2013 | 06:23 AM
  #35
Dizzog's Avatar
W211 E63 AMG
Anymore pics of this car? Did you achieve a lower ride height with the same coils
Old Jan 3, 2013 | 07:27 PM
  #36
E63 Black on Black
yeah I got lower just a tad in the rears and front since I got 215s front and 235 rears look at my thread self portrait. Im going to get 18's around spring time and be able to slam more. and take out rear perches
Old Jan 3, 2013 | 10:07 PM
  #37
E63 Black on Black
nice im going no perches soon
