Front tires rubbing
Old Nov 13, 2012 | 08:49 PM
350mbc's Avatar
C350
Front tires rubbing
I am running a 235/35/19 good year eagle on 19x8.5. With 40 mm offset on front, I am rubbing bad on the front passenger side, I have tried to cut most of the lip out on the front top of the fender, I'm still rubbing, now I'm starting to have cuts in my tire, ... Has anyone rolled there fenders on w240 or pulled fender, any suggestions on fix?
Old Nov 14, 2012 | 02:15 AM
Doanster's Avatar
C300 Sport 6MT
That's the correct tire size (I'm running the same), so asuume you're lowered? Regardless, though, if you're rubbing only on one side, then you have an issue w/ your suspension. 40mm, while a tad low, shouldn't be causing tire cutting.
Old Nov 14, 2012 | 03:37 AM
Mixedfruits's Avatar
E63 Black on Black
yeah get smaller tires aha also make sure the edges arnt to sharp
Old Nov 14, 2012 | 07:29 AM
350mbc's Avatar
C350
Not lowered, it seems it is catching the front top of the fender
Old Nov 14, 2012 | 11:11 AM
Doanster's Avatar
C300 Sport 6MT
Stock suspension you should have at least two+ fingers of gap. Blown shock IMO. Any leaking/oil on your springs or wheels?
Old Nov 14, 2012 | 11:47 AM
Cosworth2000's Avatar
2022 E53 AMG
Take a picture and show us.
Old Nov 20, 2012 | 11:10 PM
350mbc's Avatar
C350
Took the wheels off and they ended up being 35mm, just ordered a staggered set of 19s in 45mm f and r
Old Nov 21, 2012 | 02:51 AM
Doanster's Avatar
C300 Sport 6MT
That still doesn't explain why you had rubbing on only one corner of the car...
Keep us posted when you get the new wheels.
