F/S C63 Leather Steering wheel w/ airbag
1 Post
08 mercedes c350 p2
Selling a C63 Leather steering wheel with paddle shifters and the airbag. Both items are in mint condition! everything works as it should, perfect!
Price: $750 OBO + shipping
1 Post
08 mercedes c350 p2
Im exactly 4 hours and 30 min from there(give or take a few min on traffic)! I was actually just there like 2 weeks ago! lol i think it might be cheaper if i ship it to you! unless you want to drive down to like corpus or kingsville... Let me check how much it would cost to send it to SA. hold up.
1 Post
08 mercedes c350 p2
Its like $21.78 give or take a few dollars depending on exact final weight! and it says you would get it the next business day. So this would be alot cheaper than driving half way! let me know
MB C250
Thicker rim and about an inch smaller in diameter. So, feel and responsiveness are subjectively improved, but if you have any height, the view of the top of the gauges (where speedo spends most of its time) are even more blocked by 12 o'clock portion of rim.
It is a fairly easy install with the right tools. I watched mine done in just a couple of minutes, start to finish. However, to avoid an error message for the supplemental restraint system (air bag), disconnect the battery before removing the old wheel/air bag. Otherwise, a laptop or other device will need to be connected to eliminate the SRS error message created when the old bag is removed.
1 Post
08 mercedes c350 p2
Yea really easy just disconnect the negative terminal, unscrew the two 30t trox screws on the back of the steering wheel, the airbag will be loose pull it forward, then disconnect the connections behide the airbag. After u remove the airbag u will see the Center screw on the steering wheel have someone hold the steering wheel while u unscrew it! Then install new steering wheel in reverse order...
