How Wide Can I go?
How Wide Can I go?
I have read through the feeds on 18" vs. 19" wheels and have determined that I am going to play it safe and buy some aftermarket 18" wheels. I want to go a little wider on the front and rear tires. I am currently running stock 18s now. Can someone recommend a tire size and a good brand? I have attached a link to the wheels and the specs.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=160837309038
Brand: MKS Wheels
Diameter: 18 inches
Width: 8.5J front
9.5J rear
Offsets: ET 45 front / ET 50 rear
(no rub guaranteed)
Bolt pattern: 5x112
Centerbore: 66.6(direct fit)
Finish: Silver
(polished with powder clear coating)
Certifications: JWL / VIA
Weight: 22lbs front, 23lbs rear
Max Load: 815kg (1796 lbs)/ per wheel
Brand: MKS Wheels
Diameter: 18 inches
Width: 8.5J front
9.5J rear
(no rub guaranteed)
Bolt pattern: 5x112
Finish: Silver
1 Post
2015 CLA45, 2008 C300 4matic, 2011 ML350, 2001 SLK32 AMG, 2012 E550
this is what I run, I did have 275's out back but replaced with 265's as per i like the profile of the tire and gives me a little better clearance on side wall to fender
my set up:
Rims - Kleemann MS-11
Front - 19x9 ET 55, 235/25/19, 5 mill spacer
Rear - 19x10, ET 60, 265/30/19, 5 mill spacer
on Yokohamas S-Drive
NO RUBBING ! even with towing a seadoo with passengers
Photos here:
https://mbworld.org/forums/c-class-w...eady-show.html
my set up:
Photos here:
So If I'm running 18's, what would you recommend so I do not rub, but get the "wide stance" look?
my set up:
Photos here:
my set up:
Photos here:
1 Post
E63 Black on Black
hehe hmm thanks for the specs euro going 18's soon so I can go even lower ;D
do you have a facebook? wana talk to you about coil specs faster lol add me https://www.facebook.com/edward.yang.986
18x9.5" wide rims go well with 275 width tires for the rear. For the front, 245 would be good for 8.5".
With 215 OR 225 for 9.5" wide rims, you are going to be STRETCHED OUT and it will not only look silly, but also won't have the wide stance look you're going after.
More info from you needed to be 100% sure you won't rub the fenders, but I'm confident that even with the AMG sports package that has lowered suspension, you will not rub.
2010 E350
The offsets on those wheels is pretty conservative so you should be able to run some fairly wide tires on front and rear. I personally like stretched tires so I'm running 215/40 on a 8.5 ET 35 front and a 225/40 on a 9.5 ET 35 rear.
I've noticed that most people are running the 18 with an offset around +35. Is there a benefit with running offsets like that? The offsets on the wheels I purhcased, I thought would stick out to at least flush with the wheel well..
If I was going to scrap the initial specs in this post, what would you recommend. also, if there are any pics I can see that would be greatly appreciated.
2010 E350
It's all a matter of personal taste. Some like stretch and some do not. I personally hate bulging tires so I will always run stretch and yes it is safe to stretch so don't listen to the haters. A lot of drift car guys run stretch and have zero issues.
Very nice! Couple questions...
1) Why does the tire not go flush to the lip of the wheel?
2) How bad are the roads in your area? I live in DC and they are 5h!t at best with potholes, which is why i elected to stay with 18s.
3) I want my wheels to set out flush with the wheel well. With the 45f/50r offset, should I look into spacers?
I just realized something (had a newb moment)....when I say stretched, I am referring to the Stance. I want a wider stance, not so much a stretched tire/wheel. Does this make sense?
Will these fit??
Looking to buy these, but the guy at the place would not tell me if they would fit.. only buyer beware.
http://www.ebay.com/itm/19-STAGGERED...6cf3de&vxp=mtr
If anything, you can always get spacers to go more flush if the wheels you're looking for don't have the offset you want.
But a stretched out tire is NOT going to give you a wider stance.
For a wide stance, you want WIDE tires and small offset.
I've ran a 245/40/18 front and 275/35/18 rear with stock height and experienced rub. But that could also be cuz I live in NYC where the roads suck!
I went to 235/40/18 front and 265/35/18 rear and am a happy camper now.
i think it was my rear that was rubbing
but it only rubs if i have people in the back and hit a bump =P
wheel spec:
front 18x8.5 45et
rear 18x9.5 54et
wheel spec:
front 18x8.5 45et
rear 18x9.5 54et
why did you stay with 18's? I live in the DC area and the roads are not the best either. I have 18s now and can feel the road vibration when driving. I think if I go to 19s it will be worse, BUT the profile looks so much better.
I and have decided to go with the Mandrus Wilhiem wheel....now I am battling with the 18 or 19 delima.
I stayed with the 18's cause they looked better. So I purchased a bit more narrower tires and it did the trick. I don't think it's worth the headache with the 19's in NYC with all these potholes and uneven roads around.
Now it's winter, I'm riding back on my oem 17's with winter tires. (stock look)
Are you 18's Stock or after market? Got any pics?
My final Decision on Wheels.. Need Tire Size help!
After all the thread and weeks of decision making, I decided to purhcase the Mandrus Mannheim 19 Gunmetal Wheels. I now need recommendations for Wheel sizes and brand.
I need all seasons, but want a nice wide tire with an aggressive tread pattern. What do you recommned?
