xenon=present. Help Needed. Central NJ
Old Jan 4, 2013 | 12:06 AM
res2000's Avatar
c300 4matic
Can any1 help me out or recommend some1 to help me to change these settings ?
I have xentry diagnostic but can't generate password to apply these changes...
Mercedes dealership refused to help.
c300 4matic 2013
Old Jan 4, 2013 | 02:28 AM
Knightmare69's Avatar
2010 C200 CGI
Er.........maybe clarify your problem cuz I have no clue what you're talking about. Did you install a HID pnp kit and getting a dash light now or something?
Old Jan 4, 2013 | 08:10 AM
res2000's Avatar
c300 4matic
Sorry, i installed after market HID kit (with harness) at first, so there was no way to get rid off that error code on a dashboard, then I've connected everything straight to inverters but now computer senses the error (if engine is on; on battery it runs fine) lights start flickering and then go off. I tried to use capacitors with no luck.... My only suggestion would be to change xenon=present in diagnostic menu.
Old Jan 4, 2013 | 09:50 AM
2010 C200 CGI
Sounds like you don't have the proper canbus harness for your hid kits. You can get some from the retrofit source.
Old Jan 4, 2013 | 03:56 PM
res2000's Avatar
c300 4matic
well i would like to change onboard computer settings first to xenon=present to see if this will resolve the issue but I need to find someone who can do it (central nj area) or if anyone can generate xentry pass for my vin#
Old Jan 5, 2013 | 04:41 PM
mir_m's Avatar
c220
You just need a canbus hid kit changing the setting
With xentry will not help you
Old Jan 6, 2013 | 02:42 AM
2010 C200 CGI
That's what I tried telling the OP.
