Air ride gurus
1 Post
E63 Black on Black
Air ride gurus
Hey guys I have a great deal for a 5 gallon tank 2 260psi compressors all lines, switches,gauges, valves for 600$ is this a good deal?
Furthermore Im running d2 coils, can I just order brackets and bags from someone like ksport, airrex? and have a direct fit on my coils?
1 Post
E63 Black on Black
based on research all air ride is the same. Management may be more high tech, but simplicity from basic universal is ok. Bags are the same, but air rex uses hallowed double barrow meaning more low, this can be fixed with a universal setup of smaller bags. Brackets are all jsut metal can make my own. Am I right? IDK I dont know much about bags just my research
2010 E350
I'm sure if you are technically inclined to do all the fab work yourself it can be done but why waste all the time and energy only to risk damage to you or your car to save a little money?
It's personal opinion on my part but I don't see the benefits of saving a small amount of money on a hacked together set up. Buy the stuff that was engineered for your car, bolt up and done. I have all my airride stuff at my warehouse and will get it installed as soon as I have time.
1 Post
E63 Black on Black
Hmm sounds good the only thing I can save money is on the air management then. I contacted ksport and airrex they said they make brackets and bags for the car, so technically Im just going for a basic setup thats going to end up with me spending very little! and risk damage would be minimal to none on air setups am I right? What can go wrong only the bags poping and my car sitting on the floor
2011 W204 C300 mm pano
I think Wilson from stance labs is a forum member here but mostly in the e class forum he is very cool guy and is always down to help answer questions
I have had 9 bagged rides since I was 16 (30 now)
I would put some sort of air management system on the car to keep your mercedes at the same height.
You are asking for trouble if you go with a typical setup that just has switches and air gauges.
