Recall on C300 taillights, true?
Definitely a very easy thing to do yourself. Took me 15 minutes to do it in front of my SA parked right outside his office with basic tools to show him how easy it was.
Below are instruction, receipts and diagram for the rear light assembly
What I bought:
1 Plug
7 contact bushings
1 Lamp Carrier
Step1: Snip brown wire --> insert into a "contact bushing" and crimp it.
Step2: insert contact bushings into the new "plug" , same spot (it locks so don't mess up the order of wires, otherwise you will have to start over and buy a new plug)
Rinse and repeat for each wire. Once complete replace Lamp Carries (2 very easy clamps --> top and botto) and plug in "plug" into "Lamp Carrier"
You are done
2014_02_20_13_42_40.pdf
I also switched to led bulbs but I noticed the passenger side is still slightly dimmer than the drivers side but all error messages are gone.
Any advice? Should I just go ahead and change the passenger side connector too? It seems to look ok unlike the driver side.
Driver side images:
Mercedes is well aware of this issue. To quote the press releases already posted, "Mercedes acknowledged the issue. In its report, the company stated that 23,000 warranty claims tied to the brand have something to do with Mercedes tail light problems."
They just need to recall these cars and get the fix done with. On a weekly basis, I see at least one W204 with a dim taillight.
Good luck everyone!
The dealer told me they have reverted to "backup" dimmer lights. Is this BS or what?
For those who paid the dealer to have this done any estimate?
P.S., I did report this problem to the NHTSA too.
http://www.benzinsider.com/2014/04/2...ct-for-recall/
"Daimler AG (DAG) has detremined that oxidation on the ground pin connector for the rear tail lamps of subject vehicles can result in a dimming of the tail lights or complete loss of tail lamp function. The loss of a rear tail lamp reduces the rearward visibility of subject vehicles, especially with respect to turn signal illumination. This oxidation can reduce the level of illumination below that required for tail lamps by FMVSS 108 and may increase the likelihood of a rear end crash"
"Should you have any concerns, or experience any difficulty with your rear tail lamps, before you receive the next recall letter, please contact an authorized Mercedes-Benz dealer who will repair your tail lamp free of charge. If you have paid to have this recall condition corrected prior to this notice you will receive reimbursement instructions with your second recall letter.
Got the tail lamp assembly on my 2011 C300 replaced a few months ago due to a warning on the console; waiting to hear back whether it might have been related directly to this issue or not.
He then went on to say that he looked up my vin # and said that mb will be calling me due to a recall on the "light holder" and to be on the look out or a letter from them.
Has anyone else had this issue? And is this recall for real? Any help is appreciated. Also where I can find any other related info.
Thank you!
1)MB is working on getting the necessary parts in order to fix the issue, among them the circuit board that the connector plugs into.
2) In the interim (until these parts are available and owners can schedule time to come in), authorized MB dealer will repair tail lamps free of charge, regardless of warranty status
3) If the repair work was done prior to receipt of letter, then the cost of replacement will be refunded (actual quote "If you know of anyone who has paid for this replacement out-of-pocket, have them call me"). You get the point, don't call my SA hold your SA accountable
4) Once parts are in, MB will send an additional letter to owners to have them come in for replacement with the needed updated parts to fix the issue.
When I get my official letter from MB to bring the car in, should I put the OEM ones back on the car before take it to the dealer or will it be fine if I just bring in my detached OEM tail lights and have them work on it.
Do you guys think the dealer will say no if the lights are not on the car?
