Recall on C300 taillights, true?
#126
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Ok folks, today is the 18 of November/2014 and the time right now is 11:33am and I just contacted the MB line 1877-366-8888 here in CANADA Toronto, and they advice me that there is a recall on the wiring tail lights for the c350 (my baby) so now I can pretty much confirm you guys that the recall is there and is been granted.
The appointment is set to be for the next 3 weeks.
So thanks and have a grate day guys.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#129
Has anybody fixed this with OEM parts on their own? I had the recall done back in 2014, but I'm having the issue for the first time now. The dealership wouldn't redo the recall because I already had it done, and MBUSA couldn't do anything without a diagnostic performed. Don't really want to pay the expensive diagnostic fee for nothing.
I've been having intermittent errors on my dash telling me to check my right rear tail light. Lights seemed to work just fine, and I looked at the plug. One of the wires, the outermost wire, had some green corrosion on the exposed copper. Wiggling it a little caused some of it to flake off, and I haven't gotten the error again, but I still took it to the dealership, and they wanted me to go through the whole diagnostic thing, but I refused.
If it's just buying a few inexpensive parts and replacing, I'd rather do it myself.
#130
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Interesting,
my rear fogs have this issue. Or well, an issue. The passenger side one doesnt work. Could be a burnt out bulb that has nothing to do with this, but I found it ironic that it is a similar situation.
Also sorry Richard, I'm no help but I imagine you could do it yourself pretty easily. If you do some searching I'm sure something would come up.
#131
Interesting,
And I must have skipped over several posts, because there were some helpful ones. I may just get the parts I need and ground it myself. Has anybody done the DIY way and can comment on the longevity of the solution?
#133
Right tail light finally went kaput. MB USA still refuses to fix, because I already had the recall completed back in 2014. Sounds like they just replaced the parts with old parts and didn't do anything to solve the issue. Just ordered the parts to DIY, and I'll ground to the frame.
#134
2007 S550
Yes, I had the recall repair done 4 years ago, and now the same burnt-up connector, same issue. So no, the new parts didn't "fix" anything, they just kicked the can. Does anyone know how to remove the contact bushing from the connector plug, or do I need to buy 7 bushings and cut the 7 wires from the melted plug and re-crimp to the new plug?
#135
2009 Manual C300 Sport
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
#136
2007 S550
I ended up cutting the 7 wires and crimping the 7 contact bushings. No solder. Just make sure you crimp well and maybe buy 1 or 2 extra in case you don’t. The parts cost 90$ from dealer for one side. The part numbers are listed in multiple posts. Cheaper to buy online buy didn’t have that luxury. It works. I didn’t add a thicker ground cable but hopefully it lasts another 4+ years for the next owner. But yeah, sucks dealer doesn’t step up and replace again on a safety issue.
#138
Did you check the other side? When I did it, I glanced at the driver side, and I saw signs of excess heat and the same issue starting there. That was almost 2.5 years ago, and I haven't bothered to check again, but I haven't had dimming of my left tail light yet either.
#140
2010 C300 4matic sport, same issue with the right rear light assembly. Just got off the phone with MBUSA and the dealership. Since the original recall repair was done over 2 years they will not fix it again.
In my opinion they didn't fix anything, they just put the same OEM parts in place with the same issue that caused the recall to begin with.
I can't believe they don't fix the issue with better parts and will not fix a safety recall if it still has the same safety issue.
On my BMW, they had a similar issue with brake light recall and when BMW fixed it, they actually put a second ground wire in place in so that they actually fixed the recall and didn't just cover it up.
I feel like more attention needs to be brought to MBUSA or another party as this is still a safety issue where you have potential fire and failed brake lights.
If anyone has any ideas short of having to pay out of pocket for a failed recall from Mercedes, I sure would like to hear it.
#141
So odd because I'm having similar problem with my 2018 c300
As some of you are experiencing more and more problems with the melting of them, I took mine in today, the car and everything was fine before taking it in, come around 4pm central , I get a call from the dealership saying the car won't start, reads a lot of error codes, interior lights won't turn off. they set the battery to charge. it still wouldn't start. I have a loaner this weekend or until they fix the issue. they don't know what it is
1. what could it be?
2. did they fry the whole system by not changing the tail light connectors properly?
3. if it were to come down to it are they responsible for any expenses such as a possible car replacement, etc. ?
4. any other input is appreciated.
Posted from Mbworld.org App for Android
My issue began with warnings on my dash to check for left and right brake light failures. Which for some reason affected my headlights causing them to stay on even after I parked the car. I didn't want my headlights to be damaged by the heat so I disconnected the negative battery cable...the next morning after reconnecting the battery I'm dealing with a no crank no start...also my trunk is inoperable totally, idk why theres no manual way to open it in an event like this.
