eBay Rear Camera Install Success
Old Jan 20, 2013 | 02:30 PM
blueman12's Avatar
08 C300 4MATIC
Ok, so after reading many posts I decided to do it. It's not too difficult, and I did a lot of research from this forum. There are a lot of great posts but as much help as I got through this forum, there were a few missing steps.
For those thinking of doing it, the key items to remember:
1. Get the right parts/tools.
a. I purchased this CMOS camera off ebay. It costs 35 bucks and already contains a camera mount bracket that replaces your license plate light fixture. A lot of time saved! I used the right rear license plate frame to replace. You will simply take out the frame and insert the existing bulb on top. It also has a long RCA extension
http://www.ebay.com/itm/2007-12-Merc...80852834875%26
b.Get the 4 piece pry bar kit from Harbor Freight. Use these tools to help remove trim and work the wiring
c. Get an Add-A-Circuit from Autozone
d. Get eletrical tape
e. Get extra 14 gauge wire (20 ft) - red and black
f. RCA to Fakra cable from Mid-City engineering.
g. have a Torx 20 screwdriver/ratchet set
2. Go to the HU menu and enable the rear view camera. Many posts on this.
2. Go to youtube for the Mid-city engineering VIM install video to understand how to remove the COMAND unit. From there you will connect the Fakra-RCA cable.
3. I wired through the passenger headliner. You will need to get your RCA video (and ACC reverse switch wire) through to the back. This is the most difficult part of the job: getting the wiring from the front COMAND unit to the rear SAM. I went under the glovebox and through the headliner. People will say it is easy, but only after you have done it once.
4. I powered the camera through fuse 71 using an add-a-circuit. I connected the Video power and ACC reverse switch wire to this line (my camera came with both a power line and reverse switch line). For the add-a-circuit, remove the 15 amp blue fuse 71 from the rear SAM, and simply add it to the top slot on the add-a-circuit (it will have 2 fuse slots).
5. Removing the outer chrome trunk trim piece is difficult. YOU WILL scratch your car, so follow the recommendation to put masking tape on the edges.
Everything else is straight-forward and being tidy. It took me 3-4 hours...
Old Jan 20, 2013 | 03:04 PM
Konquest's Avatar
c300
Blueman do you have an issue with the camera viewing angle? I purchased the same one and the picture works great but the camera points too far down and I wasn't able to adjust it.
Old Jan 20, 2013 | 04:56 PM
blueman12's Avatar
08 C300 4MATIC
It's a bit low. I adjusted it up to I improve the viewing angle. I carefully adjusted the camera in the mount. It might sound like a snap, but it sticks.
Old Jan 20, 2013 | 05:00 PM
Konquest's Avatar
c300
How did you adjust it? Just rotate the camera itself in the housing?
Old Jan 20, 2013 | 09:31 PM
blueman12's Avatar
08 C300 4MATIC
Yes. You can adjust and glue as well
