c250 BMS Intake rubbing issues
Old Apr 22, 2013 | 08:49 AM
  #51
dav461's Avatar
GTR
does it have same sound as one BMS supplied?
Old Apr 22, 2013 | 09:09 AM
  #52
DecemberHeat's Avatar
C200 CGI
It sounds exactly the same and I have one to sell. Both ru5111 attach with bms adapter as I prefer no sound personally.
Anyway, this setup would rub for sure.
Old Apr 22, 2013 | 12:15 PM
  #53
kevink2's Avatar
2004 Mazda6, 1993 RX7
Originally Posted by Knightmare69
I'm not sure if bigger would really bring much benefit. I have however considered a longer cone filter, one which would fill in the space of the box more but since the current one works I have no need to mess with it.
Looks good!
Broken record here ... that's exactly why the Dwyer pressure drop gauge would be extremely handy. You could tell (w/o dyno) if any filter is choking airflow. You can also check adequacy of TB size, and overall intake stream.
If you get on K&N chat, they will get the flow rates, based on a standard small pressure drop.
Also, rather than a top cover for your custom filter, consider using the underside of the hood to make a cold air flow channel to the front.
Old Apr 22, 2013 | 12:20 PM
  #54
dav461's Avatar
GTR
so even with new filter ru5111 it is still rubbing?
Old Apr 23, 2013 | 01:03 AM
  #55
Knightmare69's Avatar
2010 C200 CGI
No, with. Ru5111 it won't rub.
Old May 2, 2013 | 02:26 AM
  #56
C200 CGI
My bad, I mean with RU-5111, it won't rub for sure. Plenty of space between.
Old May 2, 2013 | 12:21 PM
  #57
paleface's Avatar
C250 Coupe 2011 AMG Package
I already change the filter to
This is my new one
Not sure abt the durability, but im sure my car more responsive using this filter
Old May 2, 2013 | 07:18 PM
  #58
Kevin82's Avatar
2012 c250 Coupe
This is my new one
If that is just a foam filter, I would be careful about using those. I hear the filtering is not that great. But then again K&N is not that great at filtering too.
Old May 2, 2013 | 10:47 PM
  #59
paleface's Avatar
It has 2layer. You can google it pipercross filter
Old Jun 15, 2013 | 07:30 PM
  #60
dav461's Avatar
GTR
Does anyone know what is the K&N filter number which is supplied by BMS ?
Old Jun 20, 2013 | 01:35 AM
  #61
2010 C200 CGI
If you need a replacement, BMS sells them. Otherwise you should swap to a smaller one that we mentioned in the thread.
Old Jun 20, 2013 | 08:09 AM
  #62
fireline43's Avatar
2013 C250 Sport
I put this type of intake on my bmw 335i before and had heat soak like crazy. It's not like with the c250?
Old Jun 20, 2013 | 09:01 PM
  #63
2010 C200 CGI
It is with ours also, that's why I swapped back to OEM with a K&N panel filter and covered the box with DEI heat reflective tape. I keep the cone filter around for cooler weather or days when I wanna be obnoxious.
Old Jun 21, 2013 | 06:16 AM
  #64
fireline43's Avatar
2013 C250 Sport
Do you really notice any difference with the panel filter? I've put them in cars in the past and didn't really notice any difference except I paid more for an air filter. I feel like the airbox in the c250 is just dieing for something aftermarket though. The air movement doesn't seem fluid.
Old Jun 21, 2013 | 10:05 PM
  #65
2010 C200 CGI
Truthfully, most high flow filters panel or cone I feel are more used up top in the higher rpm's rather than down low. The cone filter will be worse because it sits right next to the engine on our cars and is exposed to a great deal of hot air. I watched a video on YouTube when They dispelled gains through a cone filter vs panel filter.
Though it can't be taken as a sole concrete evidence, the more I thought about it and looked at the engine bay, the more it made sense. Their conclusion was the cone lost power over the panel, a high flow panel lost over a stock panel but still made more than a cone. I opted to lose a bit and run a high flow panel and I applied heat reflective take to my airbox to try and minimize the heat effect.
Old Jun 21, 2013 | 11:45 PM
  #66
fireline43's Avatar
2013 C250 Sport
Sounds good. I haven't found a good aftermarket with German as it is with American cars. Volant makes awesome intake boxes but you cant get a German solution.
And btw, go knights!
Old Sep 27, 2013 | 01:27 PM
  #67
Jon@BMS's Avatar
SPONSOR
Hi guys,
Just as an update there are several hundred of the standard larger filter out without issue. But, if any of you want to use the smaller RU-5111 filter we can also supply those with the intake for the same price. Just email us when ordering.
Old Dec 19, 2016 | 03:54 PM
  #68
Ericv13's Avatar
2013 C250
After market K&N air filter
What are the dimensions or part number for the long cone style k&n air filter for 2013 C250 ?
Originally Posted by kevink2
Looks good!
