c250 BMS Intake rubbing issues
To sum it up my BMS intake was rubbing causing a hole to develop in the intake and I wanted to see if anyone was experiencing the same issue. Thanks.
If you need a replacement filter we have those for $40 shipped. We suggest cleaning or replacing them every 10-15k miles. If cleaning use a normal K&N cleaning kit.
1) When installing adjust the filter so its not touching anything, including the bottom of the airbox. You have two points of adjustment. The angle the metal tube is inserted in the OEM accordion, and the angle the filter is inserted on the metal tube.
2) If the filter is touching and is scuffed, etc, it's not much of an issue. But if it stays that way long enough you may eventually rub a hole in it. Once there is a hole in it we'd suggest replacing it with a new filter. Really nothing to panic over, though.
3) If you ever need a new filter or don't feel like cleaning it at the 10-15k service interval we offer them for the discounted price of $30 + shipping. Shipping is $10 within the USA. Internationals email as it varies by country. We don't have it listed on the site so just email orders@burgertuning.com to take advantage of that discount.
If anyone has any additional questions or needs additional info feel free to email me @ terry@burgertuning.com
I've also tried adjusting the adapter but it can only seat in one way, after that you're bound to it's position in order to adjust the filter. Again, before this gets too heated, I'd like to wait and see if any other owners are having this issue, it is entirely possible that we installed it incorrectly so to speak but after looking over the filter and space for me personally, I find it hard do so. However, if other members are having this problem then I think it might be time for BMS to consider that there is a design issue.
We have no plans to change the filter design given there are almost 1000 out in use without issue. But if you are the DIY type you are welcome to stick whatever filter you'd like on the end of our piping.
I'm going to check my intake later to see if it's rubbing. Just bought the BMS intake a month ago...
People who have no issues are most likely consumers like me, who are unaware of this issue until they open their hood and remove the BMS intake (which no one would do unless needed do, such as cleaning the filters), thus explaining why no one has this problem except a few members. Thanks to those for pointing out this problem to bring awareness of this issue for the ~1000 BMS intake owners.
If indeed mine is rubbing and there's no way to fix it given the above solution by Terry, I do hope BMS gives us some sort of compromise.
I do hope it's user installation error....
the other rub point:
dust:
only been 3000km since install. Tried adjusting and rotating the angle but not much room to rotate. because of the engine cover.
