Transmission Lag - Dealer Invoice
Old Mar 21, 2013 | 08:46 AM
beneliezer's Avatar
'11 W204 C300
Some members were looking for specifics on the software update used by MB dealerships to adjust the transmission lag in the W204 C300. I am providing a copy of my invoice to the community. I can't say I see any specific software revision notices on here, though. They also performed a recall on solenoid while it was in. Anyways, hope it helps someone.
File Type: pdf
Old Mar 21, 2013 | 12:26 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
Thanks for posting it. Did they fix the problem, and did it help in any other ways?
Old Mar 21, 2013 | 12:34 PM
beneliezer's Avatar
'11 W204 C300
It DID tremendously help. Though its not 100% gone, I can attest to an 75% improvement in the lag. As far as the manual gear changes not responding immediately, this is by design, and somewhat a result of my driving style (i.e. sometimes I drive it like you would a true standard, letting off the gas before shifting. I found that if I shift while still on the accelerator, the transmission will shift on demand.
Old Mar 21, 2013 | 12:58 PM
B Marques's Avatar
2010 C300 4Matic, 2011 GL450, 2005 ML500, 2010 GL350 and 2003 SLK230
I have same issue.
Old Mar 21, 2013 | 01:49 PM
beneliezer's Avatar
'11 W204 C300
Originally Posted by B Marques
I have same issue.
If you are referring to this statement:
I found I can get the desired effect by releasing my foot from the accelerator right after hitting the shifter.
