Wheels with 35 offset for 09 C300
Will they work??
Bolt Pattern: 5X112mm
Offset: 35mm
Hub Bore Size: 66.6MM
Quantity: 1 Set (4 Wheels)
Offset: 35mm
2010 C200 CGI
I don't remember our bore size but yes it will work even if you're on super sports but run 225/40/18 tires to avoid possible rubbing. I'm running +33 on the rear and +35 on the front 18x8.5 all around.
Nico Candelario (04-08-2020)
1 Post
2012 E350 RWD
Yes it'll work with 225/40 like knight said. Our bore size I believe is 66.56 so it'll work.
Only thing about not running a staggered set up is that the front will probably poke out more than the front. You can ask knightmare about that since he's running close to your specs.
