LED DRL - Always on ?
Old Apr 22, 2013 | 10:38 PM
rafiki47's Avatar
C300
Hello Everyone,
I tried searching the forum but I was unable to find anything. I was wondering if there is a thread that explains how to wire up the DRL so they are always on when the car is running ?
Old Apr 22, 2013 | 10:40 PM
Go Navy's Avatar
None
What's a DRL?
Old Apr 22, 2013 | 11:06 PM
rafiki47's Avatar
C300
Originally Posted by Go Navy
What's a DRL?
Daytime Running Lights
Old Apr 22, 2013 | 11:13 PM
This is a Lamp's Avatar
2010' C250 W204
I thought DRLs are always on unless turned off from the Instrument Cluster or the headlight dial?
Only when I switch off the car then it'll switch off.
Old Apr 23, 2013 | 12:37 AM
xjaymzzx's Avatar
2002 slk 32 amg, 2013 c300 4matic sport
I like mine to be off, unless the headlights are on then it'll look awsome
Old Nov 4, 2013 | 07:33 PM
Willis1550's Avatar
2011 C300
Has anyone figured out how to modify the wiring on this yet?
Old Nov 4, 2013 | 07:39 PM
janusgrimnitz's Avatar
C200 4matic
I have asked several companies in Shanghai and they all say no... Dont understand why its so hard to have these on.. Must be a simply software update.
Old Nov 4, 2013 | 07:42 PM
Thaa kiid Jlee's Avatar
2011 c300 4matic
i tapped it into my side marker so mine are always on.
Old Nov 4, 2013 | 08:02 PM
Willis1550's Avatar
2011 C300
So you just butt spliced the power wire from the side markers? And they run full power? any errors?
Old Nov 4, 2013 | 08:40 PM
2011 c300 4matic
yeah there is a DIY on here somewhere. No errors when i was on the stock bulbs. When I installed aznoptics leds, my drivers side flashes every now and then and when i want to run my eyebrows on that drl sometimes does not light. I need to replace the bulb tho i believe.
Old Nov 5, 2013 | 01:38 AM
Doanster's Avatar
C300 Sport 6MT
Willis, read page two of the thread below. I have a link in there for a simple harness that will light up the DRLs when the ignition is switched out of position one and will turn off a few seconds after the key is removed.
https://mbworld.org/forums/c-class-w...se-drls-2.html
