Intermittent "Check rear right turn signal" error
I have an '09 P2 package with the LED turn signal. I checked and everything is working fine.
What else should I check? could this be related to a fuse or the well-known melting harness connector which is having intermittent contact issues? I did apply the 2nd ground fix about 2 months ago but I didn't change the original connector harness.
