Tyre choice
Old Jul 12, 2013 | 03:25 PM
macolam1123's Avatar
2012 C200 AMG package
Tyre choice
Hi all,
I got a set of Rays G25 ,F:19×8.5J +45 on 235/30/19 PSS tires, R: 19×9.5J +50 on 265/30/19 PSSs,as my other post mentioned ,they rub when there are 4 or more people onboard and corner on rough roads.
https://mbworld.org/forums/c-class-w...adly-my-c.html
One of the members suggested that this is due to the wider tread width of the PSSs.
Tirerack said the front tires has 9" tread width and 10"for rear.
If I change to RE11s ,F:225/40/19 ,tread width 8.2",R:245/35/19,tread width 9",
or PSS F:225/40/19,tread width 8.2",R:255/35/19,treadwidth 9.2" would I fix the rubbing problem?
PS,would anyone know how wide the inner fender lips are on the C ?
Thanks in advance
Old Jul 13, 2013 | 09:42 AM
Knightmare69's Avatar
2010 C200 CGI
Re11's are completely different from pss's maybe you should consider contisportcontact 5p
Old Jul 13, 2013 | 10:03 AM
I visited my tire shop today about this and he said it's a piece of cake to fix, after some hours and some magic tricks, rubbing was solved, just that he won't tell me what he's done to fix It...
Old Jul 13, 2013 | 08:53 PM
2010 C200 CGI
Maybe he adjusted the camber? Or he might've rolled your fenders a bit.
Old Jul 14, 2013 | 12:24 AM
The camber of stock suspension can be adjusted? This is also one of the possibility I thought of and the rear wheel does seems to carry more negative camber ,but my ignorance made me ruled out this possibility at first
Old Jul 14, 2013 | 06:41 AM
2010 C200 CGI
Yes, stock arms have a certain degree of adjustability, its how most shops make alignments. For those with excessive lowering sometimes special arms and components are needed.
