Help to replace the door pin!
Old Jul 21, 2013 | 01:33 PM
mrmarie's Avatar
C-CLass w204
Hello,
I get the AMG door pin for facelift w204, need your help to know how can replace them.
Old Jul 21, 2013 | 07:14 PM
OCDBenz's Avatar
2012 C300 4Matic Sport Palladium Silver
Pretty simple. The front ones unscrew counterclockwise. The rear ones just pull off. For the rear, use a pair of pliers and gently twist back and forth while pulling up. The new ones screw on the front and push on the back. Use a drop of super glue on the back ones. One of mine actually popped off and got lost.
Old Jul 22, 2013 | 10:37 AM
vipsa's Avatar
'09 C350
On the rear I would strongly suggest you wrap the pliers with some cloth to prevent any accidents. Also, keep your head out of the way when pulling. I ended up with split eyebrow by not following those precautions.
Another suggestion is to remove the rear door panels and actually pop the pins in place. The door panels come off in 5 minutes and the pins stay there much better.
Old Jul 22, 2013 | 01:34 PM
mrmarie's Avatar
C-CLass w204
Thank you all
Old Jul 23, 2013 | 12:31 AM
dolvio's Avatar
2010 C250 4Matic
Any tips on process to do this...?
