Brake fluid flush - DIY or have a mechanic do it?
I want to do it myself but would have to do it the manual pumping way, im worried i may screw up the brake booster. I'm usually pretty good with cars and do all the maintenace my self but wondering if i should have my mechanic do this, what do you all think ? Is it an easy job if i just make sure no air gets in the system and i dont push the pedal too far or should i have it done?
Sounds as if you have all the fields covered. Why not give it a go.
I do mine with air pressure from my $100 Chinese air compressor but you can buy a unit with a hand pump.
Make sure you use Dot 4 fluid with a recent date of manufacture stamped on it.
Also do the calliper bleeding in the correct order.
There is plenty of methodology on line . Here is one :-
Introduction:
Did you know that you should regularly flush your brake fluid? Most people don’t and here is why you should do it, regularly.
Brake fluid is hygroscopic. That means it loves to absorb water like a sponge and likes it so much it will suck water right out of the air. As it absorbs water two bad things happen. First is that it causes the boiling point of the fluid to go down reducing braking performance, and second, the moister causes the brake fluid to become corrosive and can damage brake system parts, very expensive brake system parts.
The brakes generate lots of heat and the fluid in the brakes can get very hot. If it gets hot enough it can boil, and when it does it goes from a liquid to a gas. Remember back in school you leaned that fluids don’t compress well? That is the whole concept behind hydraulic brake systems. The brake fluid does not compress so it passes energy from the master cylinder that is connected to the brake pedal to the wheel cylinders, or calipers where the pads press against the rotors or drums to stop your car. This all works well as long as the brake fluid remains a liquid. If it gets to hot it will boil and transform its self from a liquid to a gas. Remember air is a gas and you can really compress it, a lot. You can take a lot of gas and compress it and put it in to a small place like a scuba tank. The bad thing is that it will not transfer energy to the brake pads like liquid brake fluid can.
Once your brake fluid boils, your brake pedal can go right to the floor and have little to NO affect on getting the brakes to stop the car. This has happened to me several times in my work cars, but NEVER in any of my personal cars.
Back to page index
DOT Types and Boiling Points:
DOT 3 brake fluid has a minimum boiling point of 400 degrees Fahrenheit. DOT 4 has a minimum boil of 450 Degrees. DOT 5 and 5.1 has a minimum boiling point of 500 degrees Fahrenheit, but they are not compatible with normal brake systems and are used in special racecar brake systems. DOT 5 is a silicone fluid and will foam in ABS systems and you will have no brakes. DOT 5.1 is non-silicone, but neither one is compatible with the Toyota brake system so forget about it.
If your system is labeled for DOT 3 you can use DOT 3 or 4 and they can be mixed if needed. I use DOT 4 in my vehicles.
The minimum boiling point ratings are as the fluid sits in its factory sealed container. As soon as you open the container it starts to absorb moisture and the boiling point starts to drop. When you add brake fluid always make sure you do so from a factory sealed container.
Back to page index
Corrosion:
As brake fluid absorbs moisture it can become corrosive and damage very expensive brake system parts like a $1400 ABS modulator pump. A few dollars spent regularly flushing you brake system can save you thousands down the road especially in modern brake systems with all kinds of fancy stuff like ABS, Traction Control, Vehicle Skid Control, and so on. Your brake system should be flushed yearly, but never longer then every two years.
Back to page index
Flush your brakes:
Brake fluid absorbs water from the atmosphere, lowering its boiling point and causing corrosion, particulate contamination, microscopic particles of rust and rubber accelerating the wear of very expensive brake components. This is why you should fully flush your brake system every year, but never more then every two years. In addition, whenever the hydraulic system has been opened like when a component is replaced, the system must be bled of air.
Back to page index
Flushing Methods:
The brake pedal method:
This can be done with two people or one with a “one man bleeding kit”. The one man bleeding kit has a check valve that you attach to the wheel cylinder so air does not get drawn back into the system.
Everyone knows about this method, but few know how bad it can be. Normally the piston, which is connected to the brake pedal, only travels so far in the master cylinder. When using the brake pedal flushing method, the piston can travel much further down in the master cylinder and contact an area that has never been touched by the piston or its sealing O-ring. If the area has corrosion in it you can ruin the O-ring in just one pass and then you will need a new master cylinder. This is most likely going to occur in a vehicle where brake flushing has not been done as often as it should have been. If it has been neglected then you should only have it power flushed.
Knowing that and you want to proceed you should check the shop manual and make sure that your brakes can be flushed this way. Some GM cars cannot and they can only be flushed with a special computer that interfaces with the ABS system. I can tell you that my 96 4Runner can be flushed this way.
Determine how far down the brake pedal normally goes and put a block of wood under it to prevent it from going further down to prevent O-ring damage. Next using a NEW turkey baster, not a used one so you do not contaminate the brake fluid and system. Our use my favorite, a large sterile medical syringe. Clean the outside of the master cylinder and reservoir to make sure no dirt can get into the brake system. Remove the cap and use the turkey baster to remove as much of the old fluid as you can and top it off with new fluid from a factory sealed container. Then go to the wheel cylinder that is furthest from the master cylinder. On most cars that will be the right rear wheel, on the 3rd generation 4Runner with ABS it will be the left rear wheel. Apply a 10mm box end wrench to the bleeder valve and a clear tube that goes into a collection container and you are ready to start.
Tell your helper to apply pressure to the brake pedal while you open the bleeder valve. Have your helper tell you when the pedal is against the block of wood and hold it there until you close the valve. Let him know to let the pedal up. It is important that he allows it to come all the way up for a few seconds while the master cylinder refills. Keep going until you see nice new clear fluid free of bubbles coming out of the bleeder valve. Stop and move to the next closest wheel to the master cylinder and so on until you get them all. It is very important that you never let the level in the master cylinder reservoir drop below the MIN mark or you may get air into the system and have to start all over again. Once you complete the last wheel, top off the reservoir and go for a careful test drive. If the brakes are mushy that means you got air into the system and have to do it again until you get it all out. Now you are done until next year.
Here is another nifty idea. There is a company called Speed Bleeder that sells a replacement bleeder valve that has a check valve built right in. It looks like it would speed up the bleeding process especially if you had to do it by yourself. The only thing is that for the speed bleeder to work properly the threads would have to remain air tight so the valves would have to be removed from time to time to apply more thread sealant.
Reverse Injection:
There is some new equipment out that is for reverse injection of brake fluid. The idea here is that you force new fluid into the wheel cylinders through the bleeder valve and flush the old fluid back out the master cylinder.
I have one of these systems and flat do not like it. I just do not think I can get the bleeder valve clean enough so I do not force dirt into the brake system. I also feel that the fluid in the wheel cylinders is where it gets the hottest and maybe in the worst shape and I sure do not want to force the worst, dirtiest brake fluid backwards through the ABS modulator pump and the rest of the brake system.
I may just be old fashioned here, but I just do not think this is a good idea.
The reverse injector system can also be used to apply suction to the bleeder valve and such the old fluid out the bleeder valve. I have tried this several time and I keep getting air sucked in past the threads of the bleeder valve into the wheel cylinder and it appears to me that I can not get all the air out of the wheel cylinder. Overall the only thing I like about my reverse injection kit is the nifty collection bottle that I use when power flushing the brake system.
Power Flushing:
Power flushing is the ticket for flushing the brake system and you do not have to worry about damage to the master cylinder like in the brake pedal method.
The professional power flushing systems have a big aluminum gadget that looks like a beer keg. It has two chambers in it that is separated by a diaphragm. One side of the diaphragm is the new brake fluid and the other is compressed air. A hose is clamped on to the opening of the master cylinder reservoir to supply the reservoir with fresh fluid. The tank is hooked up to the shops compressed air line and puts about 15 PSI on the diaphragm which forces the new fluid into the master cylinder reservoir and keeps it under positive pressure. Then all your have to do is go around to the different wheel cylinders and allow the fluid to flow out until you see nice new fluid coming out of the bleeder valve. This works really well, but the equipment is expensive and you need shop air to drive it.
I just found a power flusher tank that works really well for the do it yourselfers.
I got one from Motive Products and it sells for $49.95 for model PBU101.
It works the very same way as the professional power flushing systems, just on a smaller scale. You connect the hose with the universal adapter to the opening of the master cylinder reservoir and dump two quarts of new fluid into the tank and pump it up to 15 PSI and then run around and bleed it out of the wheel cylinders. I was able to flush the brake systems in all three of my vehicles in about an hour and a half. It is fast and really easy to use. For the money it is a must have item. Many shops charge well over $100 to flush a brake system. You can get one of these tanks and do it yourself for $49.95 for the tanks and $20 in new fluid. From then on all you need is the fluid.
Also here is a make it yourself system bleeder.
The Making of the Inexpensive
Brake Pressure Bleeder
Back in early 1999 I mentioned on the Digest(s) that my own personal brake pressure bleeder was made from a pump-up garden sprayer and some hose, a few fittings and a master cylinder cap drilled to accept another air fitting. I lent mine out to a fellow employee who liked it so much that he asked to buy it. After making a tidy $25 profit, its now time to make another one. So here we go fellow cheapskates, if you can't afford Steve D's most excellent Bleeder Cap or have learned from experience not to accidentally apply 125 PSI to your master cylinder, here's my $25 or less do-it-yourself pressure bleeder. Have an Ace Hardware in your neighborhood? You can do this.
Update I: At the Laguna Seca Driving School held 11/20-21/99 I lent my bleeder to Jay Sala. Jay was just bleeding his brakes and therefore didn't have a turkey baster with him. Why is that important? Well, most of these bleeders leave the master cylinder topped off with fluid and you need to suck out the extra fluid to get it down to the fill level line. Jay and I didn't have a baster handy. So, I made an improvement to the bleeder today to cure this little problem. Look at the last picture and instructions. I also splurged an extra $2.99 at Ace Hardware for a pressure gauge. The proper operating pressure is 15-20 psi.
Update II: A few people over the last year have asked me what to use to catch the brake fluid in when bleeding brakes. I've always told them to use a one or two liter Coke bottle with some kind of hanger to hold the bottle while you open the bleeder screws. Since I broke my bottle today, I had to make a new one. Look for the update at the bottom of the page for pictures.
Ok, here's where we start. 1/2 gallon size pump up sprayer from Ace Hardware (Model# 74497).
Next step, loosen ring connecting spray head hosing. Save in case your wife finds out what you've done and makes you put her rose sprayer back in original condition.
Now that you've loosened that pesky ring, cut the hose off if you can't get it to slip off. Then slit it down the side and peel it off. Set the original hose aside in case you ever want to reuse this thing as a sprayer. If so, remember to clean it real well first.
Yes its true. You can use a late model GM master cylinder cap (Help! p/n 42035). You have to take 5 seconds to modify it but it works fine after that. What you will find when you open the package is that the GM piece has a little groove cut in the underside of it to relieve pressure!?! I don't know what the hell that's about, but take some black (or whatever) RTV and using a scrap of the original packaging, smear the groove full of RTV and let it cure for a bit.
I didn't take pictures of every last little detail. Sue me. While at Pep Boys buying the cap, get a 1/4" hose fitting with a threaded base and associated brass nut. I also used a fender washer from my spare hardware bin on top. Drill a whole and enlarge to the size of the hose fitting. Screw that baby in there and secure from the back (see next pic) with the brass nut.
Yep just like that. Too bad it was sunny out and the flash didn't light up the inside where I put black RTV on black plastic. You would have been real impressed with the overwhelming difficulty of the job.
I left this pic full size. I imagine you can double click on the others and see them this size if you want. Connect 6 feet (or whatever you feel like) of 1/4" I.D. (for this sprayer) poly hose to the sprayer and cap. Secure with hose clamps. That is all there is. Under $25 and you are good for years, or until you sell it at a profit to a friend. Here's how you use it. Pour in 1 to 2 liters of Super Blue or Type 200 ATE brake fluid and after sucking old brake fluid out of master cylinder with your wife's best turkey baster, refill and screw the cap on. Pump it up to pressurize and start bleeding brakes. After you're done, loosen main sprayer cap slowly to relieve pressure. Suck out or fill up master cylinder to full level line and reinstall factory cap and sensor.
Update I
Here's the improvements to the bleeder. Take a small length of 1/4" OD (for the hardware I used) copper tubing and attach to the inside of the cap using either a ferrule and cap or JB Weld epoxy. I did both, just to be sure. Trim to the proper length so that when the cap is installed onto your master cylinder it will just reach the fill level line. Then when you are done flushing or bleeding your brakes, loosen the cap of the pressure bottle. You must have the bottle below the level of the master cylinder. When you do this, you will siphon the fluid back into the reservoir from the master cylinder. The fluid will siphon down to the end of the copper tubing where the siphon's vacuum will be broken and your fluid level will automatically be correct. I also drilled the tank to accept a small air/fluid pressure gauge. This will help first time users set the proper pressure of 15-20 psi when pumping the reservoir up. RTV (Silicone) the gauge in place also to make sure its air tight.
Update II
Here's the finished product. Use about a 1/3 of a coat hanger or anything else you like to make a hanger. Twist a loop into it around the neck of the bottle and squeeze it closed with a pair of large pliers.
Get yourself about 4-5 feet of 1/4" OD (outside diameter) tubing at a hardware store. Drill a hole in the bottle cap to accept it and push it about halfway into the bottle. You want the tubing to hang above the fluid draining in so you can see when it runs clean and without bubbles. When drilling the cap, it will work best to start with a small bit and work up. Using a large bit first will probably result in the bit catching in the hole and spinning the cap. And since I know all of you will drill the thing holding it in your bare hand, we wouldn't want THAT!
Happy Brake Bleeding!
Introduction:
Back to page index
Back to page index
Corrosion:
Back to page index
Flush your brakes:
Back to page index
Flushing Methods:
Reverse Injection:
Power Flushing:
Update I
Update II
