Kleeman ECU tune, 3.5L C300
2013 + models have the 3.5 motor, Mercedes detuned them to 248 HP. The C350 (which has the same motor as the 2013+ C300) has 302 HP. Kleeman is simply tuning the engine to its capabilities + 20 or so HP.
I have done this tune and speak from experience. Best tune i had ever experienced.
Again, no offense to your local tuner but i would not trust anyone touching my car except Kleeman.
Money well spent...
John
P.S. End result is typically about 315-320 HP and about 300 lb/ft. of torque.
Is there any danger of there not being enough air as my C300 only has one air intake compared to a C350 having two.
Looks like only pre-facelift C350s have dual air intakes.
You would think that 20% or more increase in power would be extremely noticeable.
Now, to give my review: First, I have never modded any car, ever. It kind of pissed me off that we had the same engine as the C350 except for electronic tuning. I came from an Infiniti G35 coupe. The difference between the Infiniti and the C300 could best be described as having a hair-trigger gas pedal(G35) and driving a dump truck (C300). Since I bought the C300, I had a hard time driving the G35 without slamming my head into the headrest at every start. Both cars were comparable in speed, the C300 just felt slower because of the pedal lag.
I was out of town until yesterday, Sunday, so I put the ECU back in and drove around town. The lag was very noticeably better. I did some heavy acceleration 0-70 runs and shifts were crisp and it pulled really well. This morning, I did the usual workday routine. The car is effortlessly accelerating with much more throttle response. That lag is gone. I don't know if it is just wishful thinking, but I could swear that I don't have to push the pedal as far to maintain speed. I'm just barely touching the pedal. When I need to accelerate, the response is instantaneous.
Finally, with only one morning of comparison with my daily commute, I would say the gas mileage is very similar before and after. If you accelerate the same as before the upgrade, you will have the same mileage. If you accelerate faster, because it is more fun or because you can, your mileage will suffer. The problem is that, because it takes a lot less effort to accelerate faster now, it will be harder to keep the same gas mileage. I am not complaining!
I recommend the upgrade.
What is it like to get to the ECU? Most I've ever done is a CAI and throttle body on a Grand Am...so I'm in new territory here...
I live in Illinois. I overnighted the ECU via FedEx. They overnighted it back. Simple.
This is the only thing i do not like about this sw upgrade. There is a bulletin for all 2013 C Class 4Matic LI07.08-P-056245. Apparently there is a new sw update for the MU control unit.
The TSB mentioned above is for a fault code related to “Implausible data received from control unit “transmission”, stored in engine control unit.” The fault code is U040208. This fault basically says the ECU has received implausible data from the transmission control unit. It is a transmission signal being sent from the gearbox controller to the ECU.
John
What's the price range on the k1?
Judging by the other 'tuners', it seems that a max increase of 15-20HP is the most a '13 C350 will get from anyone as this is its performance max without doing other things like headers and down pipes and such.
Suffice it to say that the $1300 or so for the Kleeman K1 tune is really the only viable choice for the C300...you're just not going to get a big enough increase on the C350. But from what I've seen, they are the only ones that give a target hp for the engine, rather than just a vague increase and enhanced throttle response from all the other offerings...
So for those still confused, we're discussing the 2013/2014 C300 with the 3.5L M276 DETUNED engine with 248hp and it's capability to be tuned to ~320hp. Not the 3.5L M272 in pre-facelift C350s, not the 3.0L M272 in the pre-facelift C300s.
