LED reverse lights
Old Sep 2, 2013 | 03:04 PM
vic viper's Avatar
S213
LED reverse lights
As I mentioned in another thread I am in the process of "ledifying" my car, ie. replacing all exterior halogen lights with LED.s
With a facelifted car equipped with ILS this is not much, just the rear brake lights, rear reverse lights and front head lamp cornering lights.
Had a bit of problems with the H7 front cornering lights but I will try out a new bulb soon.
Here is my new LED reverse lights, bright as f_ck
free image hosting
print screen windows xp
pc screen shot
The lights I used:
http://www.ebay.com/itm/181134312237...84.m1497.l2648
Old Sep 2, 2013 | 03:24 PM
Sportstick's Avatar
Another round of ICE
Based on you recommendation, I bought a pair as my current LEDs are quite white, but not as bright as I wish. They don't seem to have many left in current stock. I'll report back in a few weeks (long shipping time projected....I guess by boat?)
Old Sep 2, 2013 | 04:15 PM
vic viper's Avatar
S213
Got mine in a week, air freight.
Old Sep 2, 2013 | 05:57 PM
joespeed29's Avatar
2013 C300 Sport
This reminds me of the GMC/ Cadillac reverse lights. Is the output similar?
Old Sep 2, 2013 | 07:12 PM
Sentosa's Avatar
C200 Estate Kompressor W204, 2018 GLA 220d
So Vic, These are just plug and play and won't show any errors?
Old Sep 2, 2013 | 09:38 PM
Knightmare69's Avatar
2010 C200 CGI
It lists as error free for canbus systems so it shouldn't give you any warning lights. However, I have canbus specific LED bulbs also and occasionally I get error messages.
Old Sep 3, 2013 | 02:30 AM
vic viper's Avatar
S213
Yes, plug and play, no errors, however the two H7 LED bulbs i tried for my cornering lights were also listed as error free, but none of them worked.
I have a different set of BA15S for the brake lights on order as well, will let you know how they work when they arrive.
Old Sep 3, 2013 | 02:34 AM
vic viper's Avatar
S213
Havn´t seen them, those cars are pretty rare over here
Actually got the idea when looking at a new A-Class at work, they have stock LED reverse lights.
Old Sep 9, 2013 | 03:19 PM
Sportstick's Avatar
The LEDs arrived today and I put them in immediately. No error messages. Can't quite tell absolute night time effect, but when I had one side done, the left to right difference was huge vs. the LEDs I had previously. Will report again after a night time tryout.
Old Sep 10, 2013 | 01:12 AM
vic viper's Avatar
S213
Great to hear, I have ordered 4 more for use as brake lights, will report back.
Old Sep 10, 2013 | 08:59 AM
Sportstick's Avatar
Do they come in red color or will you rely on the red lens color over a white LED?
Old Sep 10, 2013 | 10:06 AM
vic viper's Avatar
S213
Ordered white, its a bit of a gamble, but red usually isnt available with the same bright intensity as these white ones.
Old Sep 10, 2013 | 09:36 PM
2010 C200 CGI
I would be careful of using LED bulbs in such an important location. I tried them once with my WRX and during the day they weren't as bright as halogen bulbs. Plus Halogen bulbs give a 360 array of light where LED's are directional so that will affect the output. It also depend on the LED bulb design, I would get ones that focus more on giving light all around as opposed to direct/rear focused ones like the ones you use for your reverse lights.
Old Sep 11, 2013 | 01:45 AM
vic viper's Avatar
S213
If you look at the lamp you will see 5050 SMD.s at the base of the bulb spreading light onto the reflector as well, these bulbs are much brighter than the stock 21W glow light bulb and I am very pleased with output and spread.
You havn´t tried the bulb I am using so I dont know why you are so concerned?
Old Sep 11, 2013 | 03:33 AM
vic viper's Avatar
S213
Havnt got any errors at all with these bulbs
Old Sep 11, 2013 | 05:10 AM
2010 C200 CGI
Actually I have which is why I mentioned it. And I'm concerned because it's a potential safety issue not just for you but for other people on the road. However with that kind of attitude I fail to see why I bothered in the first place.
Old Sep 11, 2013 | 05:16 AM
vic viper's Avatar
S213
Well I fail to see the problem when they according to me are a lot safer as they are at least 25% more visible than the yellowish glow bulb light.
In particular the light output from straight behind the car is highly improved.
Old Sep 11, 2013 | 07:36 AM
2010 C200 CGI
I could pass you information about why there's a potential issue especially during the day but you seem to have your mind set on this without thoroughly understanding how LED's and tail lamps/reflectors work. For your sake and those driving behind you I hope this works out as well as you say it will. I just know from personal experience that it's not as simple as plugging in a LED bulb, even one with the projector as I've experimented with that before. Good luck.
Old Sep 11, 2013 | 02:21 PM
vic viper's Avatar
S213
Ok, so you have come to this conclusion by trying out the lamps on a WRX, a completely different car, and reflector housing?
I made this simple comparison tonight, I fitted a stock, brand new 21W bulb in the right reflector.
Comparison:
screen shot download
Left side wall and ground reflection, see the strong output?
how to screenshot on windows
Right side glow bulb reflection, almost the exact same light shapes on wall and ground but a lot weaker and diffuse
image upload
Yes Knightmare69, I already have my mind set, these LED.s will not cause any increased hazards in traffic.
Old Sep 11, 2013 | 02:39 PM
Sportstick's Avatar
Vic,
Does the brightness of the LED wash out the redness of the brake/tail lamp or amberness of the turn signal into a whiter appearance? I know this is great for a white backup, but it's hard in a photo to assess this question about color. This was the reason I asked if the LEDs came in color. My current LEDs from AZNOptics actually illuminate in red and amber. Thanks!
Old Sep 11, 2013 | 02:46 PM
vic viper's Avatar
S213
They do actually, I have fitted a number of different LED bulbs on my wifes W203 and using red lights as rear lighting works best, however the difference is very small, but I am something of a perfectionist
I have no idea how these LED.s will look like as brake lights, but if I dont like it I will just switch back and sell them.
Then again I could always use my backup LED.s and try them in the brake lights..
Old Sep 11, 2013 | 09:17 PM
2010 C200 CGI
No, I tried them in my 2010 W204 as well, I'm glad it worked out for you. Still, your attitude leaves something to be desired. And again, I was speaking mainly about use during the daytime which you either seem to miss or ignore.
Old Sep 12, 2013 | 12:08 AM
vic viper's Avatar
S213
Then why don't you explain to me why daytime driving should be any different?
Old Sep 12, 2013 | 06:42 AM
2010 C200 CGI
Still on this? You already said you're set on this and I have moved on. Nice car btw if I never told you.
Old May 26, 2023 | 09:57 AM
Qat09's Avatar
2013 C250 Luxury RWD, 2019 Subaru Crosstrek Limited AWD
I just replaced the reverse lights and the brakes lights in my 2013 C250 Lux with these bulbs. The design diffuses the light to reduce glare and prevent that pinpoint bright spot. The backup light is certainly brighter than the halogen bulb. Brakes may not be much brighter, but I think there are still advantages to having an LED in there. These bulbs do not invoke the 'check light' error. I tried a red LED marketed specifically for brake lights but it threw the error - I don't think they drew enough power for the car to register. FWIW, I see no difference between the white LED and red LED behind the red brake light lens.
Amazon Amazon
