Megan racing coilovers 08-11 4matic
I'm still game if you guys have other locations you want to get from. The one from airtekk sounds good as well. Is that price for the full setup or is their additional equipment needed like slowc said? Ksport has one for our cars but it's going for 2900.
http://ksportusa.com/products/air-su...airtech-basic/
Let me know if you guys are still in for HotBits and we can get things going. He said he needs to build one set first test on my car make sure everything is good to go before making 5 or more units.
We will build monotube performance dampers that can be serviced in 3 US locations and 2 Canadian locations. This is for revalve, tuning, or the rare leak. We have 5 service centres capable of taking the dampers apart and tuning them. We specialize in performance and handling. Our biggest market is racing…..all kinds. Rally, Drag, Drift, Track, Targa, we have customers winning in all these areas.
I have the following pricing, this is for dampers with bodies shortened 50mm. That’s over 2 inches of body drop without loosing travel on the damper, only lowering it further would start to shorten your compression stroke.
DT1 single adjustable dampening monotube dampers. Front threaded body, rear would have separate threaded replacement spring seat all for ride height. DT1 effects bounce and rebound with a single adjustment. 40 positions. Regular price $1707cdn $1650us
DT1 kit with remote canister reservoir $1995cdn $1926us
DT2 double adjustable dampening kit. Same as DT1 but with separate control of bounce (30 positions) and rebound (40 positions), remote canisters required and included. $ 2284cdn $2203us
There are price differences between Canada and the US because of import duties and taxes. Included in the above pricing is $275 courier delivery direct from the TUV German certified factory in Malaysia.
If you can get together a group buy we will give 20% off prior to shipping for 5 orders or more. If you want everything quickly and direct, then the $275 shipping cost will still be the same. If you are not in a rush, shipping can be cut down to $100 per set if we do a sea freight shipment and then disburse via ground courier once landed. Sea takes 6 to 8 weeks shipping time. Courier is 3-4 days.
So with courier shipping, pricing for group buy would be.
DT1 kit $1420cdn $1375us
DT1 canister kit $1651cdn $1596us
DT2 canister kit $1882cdn $1817us
We can build pillow ball mounts front and rear if desired. Additional charges for these.
Do they continue to go lower then the 2 inches, just with less compression stroke as stated?
1420 shipped is a steal if you ask me..
Cheers on getting this info.
so at the highest setting the ride hide will be about 1/2 - 3/4 inch lower than stock which guarantees you'll still have fender gap more than a finger. I'm going to be going ahead and getting the coils ordered for my self for the test fit. Are you guys still in for the group buy? Also I'll be selling my KW V3 coilovers. Whoever is interested PM me and we can work out a price.
