Vinyl Wrap damage to car
2 Attachment(s)
Hey guys,
I went to have my roof wrapped by a reputable place yesterday in gloss black. When I arrived the job was terrible (bubbles/scratches). Upon further inspection they did not open the sunroof and ended up cutting the seal of the sunroof badly. I was fuming mad and they agreed to pay for it. I also had the vinyl removed as the job was garbage. Today I noticed they nicked my rear antenna rubber. I talked to MB today and they said this should be fine and they checked and it's still sealed. It's a rather big job apparently to have the dealer fix this this. MB recommended leaving it. Should I be worried about future water leaks and decay of the seal? I'm looking for someone who has experience in this area and not speculation. Yes, I am beyond choked at this business. I was told by the manager they did not know how to open the roof. Yep, unbelievable. 1st pic is torn roof seal and it's now been fixed. 2nd is rear antenna seal. Thanks, AH |
I would have it fixed, it's only going to get worse over time and now that the seal has been damaged, will be prone to weathering and rot quicker. They should pay for that too. Are these guys amateurs or what?
Originally Posted by xXHotelCrazyXx
(Post 5805448)
The company needs to fix that also, if they damaged it i would get it fixed, I don't know why mb is saying leave it alone...their techs are supposed to be some of the best out there
Originally Posted by dolvio
(Post 5805416)
Hey guys,
Damn bro sorry to hear this happened to you!
Hope it gets fixed though without you having to put the money out for it. |
Originally Posted by Goni C63
(Post 5806680)
It is easy to replace, just start from one side and start pulling the rubber out, and then just start tucking in the new one,I did mine my self had the same problem when they were doing my vinal roof so all together will take you 30min! :)
Isn't the rear fin just attached by one screw located under the rear dome light (as per this thread)... so wouldn't you just need a new rubber grommit, unscrew the fin, pop old one out, pop new one in and screw the fin back on? Sounds like a 20 minute job...
(Post 5807071)
Hi. I don't understand. You are talking about the rear antenna right? Can you explain?
(Post 5807238)
No im talking about your rubber that goes around your sunroof glass, that rubber that been damaged can be changes if 30min
Thanks, A |
Originally Posted by Drazil
(Post 5807230)
i believe you have to remove the headliner in order to access the antenna. I would change it since they are covering repair costs.
Originally Posted by J__
(Post 5809713)
(Post 5810372)
After washing my car today the seal is breathing in and out water. Meaning, it takes water in and holds.. I need to have it fixed for sure now. :mad::mad::mad::mad:
Went to the dealer and spoke to my regular guy. Looks like they can access ot through the rear dome light. My guy said "we have a ton of tricks for many car repairs buy we always quote the proper way of doing it" lol
